Re: Bottom Engine Steady bar bush?
I
think mine looked like the MGF's tie rod bush KKH100782.
You'd just have to push out the bush on yours and the above and swap em.
Mine started to allow too much movement (so I thought) and was replaced with home made PU top hat bushes (you actually can buy polybushes for this application). I cut all the rubber out but didn't bother removing the sleeve & retained the centre tube.
