Dino
 Re: Cox GTM ('67-'68)
| Fri Jan 22, 2010 9:33 pm |
CamelotR
One step closer.
| Sat Jan 23, 2010 9:48 pm |
Mr Mac
Joined: Thu Dec 24, 2009 9:31 pm Posts: 106 Location: NW Leicestershire
| Sat Jan 23, 2010 10:33 pm |
epuoC MTG (591)
Joined: Fri Nov 09, 2007 6:09 pm Posts: 131 Location: Burntwood, Staffs
_________________ Regards, Pete. GTM Coupe No.1 (under construction). GTM Coupe No.2 (under review). Rover 25 (regular use tin-top). DAF 85.460 (company 'car').
| Sun Jan 24, 2010 4:25 pm |
turbocox
Joined: Mon Oct 01, 2007 7:25 pm Posts: 508 Location: milton keynes
_________________ THE WORLD'S FASTEST 'A' SERIES COX GTM 1/4....13.502 @115mph MITP 08
| Mon Jan 25, 2010 3:52 pm |
CamelotR
Hi everybody!
Unfortunatly it looks like for registration the authorities will need the build manual to compare the car to this. Does any of You have a Cox GTM or early Heerey GTM build manual?
| Sat Mar 06, 2010 7:23 am |
Andy
Joined: Thu Nov 15, 2007 10:22 pm Posts: 353 Location: Ireland
Yes I do, PM me your email address and I will send it to you
| Sat Mar 06, 2010 10:45 am |
CamelotR
Does any of You know who owns the rights of the Coupe nowdays? I may need a direct aprovement that my car is an original Cox GTM as the registry does not know this brand  .
| Mon Mar 08, 2010 8:19 pm |
epuoC MTG (591)
Pretty sure this has come up in discussion before on the forum.. the gist of it being that so far as Westfield were concerned, the rights to the Cox silhouette were passed on to Primo on purchase of the Coupe model etc. I may be wrong of course... doesn't bode well for getting the approval that you need...
| Mon Mar 08, 2010 9:24 pm |
Andy
I have some original documentation that came with my car all abot the Coupe, its history, manufactures etc, I will copy this in the mail I sending you, this should help
| Mon Mar 08, 2010 10:59 pm |
CamelotR
Thanks a lot again.
| Tue Mar 09, 2010 7:09 am |
CamelotR
Today I have started the engne of the Cox (the ill engine is for my other project, a Wolseley Hornet). This engine is running without a puff of smoke. Although the idle is a b-i-t lumpy with the lightened flywheel and the kent 276 cam, it is quite responsive and sounds like a REAL sportscar  .
| Thu Mar 11, 2010 8:42 pm |
CamelotR
Greetings Andy,
Thanks for the pack, Youre a GENTLEMAN!!!!!!!!!!
Gergo
| Tue Mar 16, 2010 3:52 pm |
Joined: Fri Sep 14, 2007 10:34 pm Posts: 883 Location: Somewhere between VTEC and redline
CamelotR wrote: Today I have started the engne of the Cox (the ill engine is for my other project, a Wolseley Hornet). This engine is running without a puff of smoke. Although the idle is a b-i-t lumpy with the lightened flywheel and the kent 276 cam, it is quite responsive and sounds like a REAL sportscar  . Is it a normal 276 or a Scatter cam 276, they sound really menacing Neil
_________________ IF wile e coyote had a GTM he would have one with Nitrous too! watch out road runner! The First GTM into the 11s, PB 11.00 @ 124.98 Mph on A048 tyres!
| Tue Mar 16, 2010 8:41 pm |
CamelotR
Normal kent276. Runs ok. Pulls strong from 2000 without problem (just a BIT of smoke, nothing else  ).
| Tue Mar 16, 2010 9:37 pm |
