It is currently Wed Feb 20, 2019 7:43 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
different rear arms/hub locking
Post Re: different rear arms/hub locking
Mr Mac wrote:
You got a drawing of the block or was it done the traditional way?
I drew a picture for the machinist, I'll have a look tomorrow, I did have it in a folder.
Whats the traditional way :?: :?
Wed Oct 19, 2011 8:39 pm
The "traditional" way would be to give the hub to a real engineer and tell him what you wanted back............
And that's what would come back!!!!! :lol:
Wed Oct 19, 2011 8:48 pm
I'm not sure how to take that. :?
Am I miss-interpreting, is that aimed at me :?:
I was trying to help :?
Wed Oct 19, 2011 10:08 pm
Please don't take that the wrong way, no insult intended!
Loads of very clever solutions were one off's with no documentation to support them that survived - hence my question - a really good bit of engineering.
Sorry, I didn't mean to cause any offence.
Wed Oct 19, 2011 10:40 pm
In case anybody is not familiar with the locking system kit available from Rossabitz,
I have attempted to attach a drawing. The kit is bolt-on without the need to
modify any parts. It is only suitable for use with 13" wheels.
A new top arm replaces the Mini steering arm with locating bushes and spacers
to the top of the hub.
The outer rose joint is aligned with the hub top ball joint and the inner rose
joint is mounted on an extension screwed to the end of the Mini top arm pivot shaft.
A reinforcing bracket links back to the sub frame at the point where the GTM triangular
plate used to attach.
The rose joints (1/2UNF LH & RH which aren't included in kit) can be female if using the standard GTM
track rod as shown, or male if using a tie bar available from Mcgill.
Holes are provided in the top arm to accept a handbrake caliper kit and if using drum
brakes the hand brake cable can be fitted to a front lug.
Please contact me directly if you require further details.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Thu Oct 20, 2011 7:34 pm
Right I have found the drawing, it was buried in the filling cabinet in the shed.
If anyone wants a copy pm me and I'll copy it for you.
:idea: Rossabitz system is also an option :wink:
(Mr Mac no worries, just wasn't sure what you ment :D )
Mon Oct 24, 2011 8:41 pm
Interesting item:
http://www.ebay.co.uk/itm/UPRIGHTS-4-WI ... 20be2baff9
Thu Nov 03, 2011 10:31 pm
