It is currently Thu Sep 19, 2019 6:02 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4  Next
Dino's Coupe
Post Re: Dino's Coupe
Good effort chap! 8)
see you at Avon park then :D
Low 14seconds ? or mid 13's ?
I had a coupe a while back, with one of the rear arch intakes, I think it made mine look horrid :cry:
Are you going to remove it :?:
Wed Mar 19, 2008 3:43 pm
Looking good :) It must be a bit heavier than when you started :lol:
I was told at Race Retro that if you used part of the cage as the column support the column should now be below and not above it, could worth checking :wink:
Wed Mar 19, 2008 10:28 pm
alexh wrote:
...your pictures nearly put me off getting a coupe-..
Oh I hope not, I deliberately bought something needing restoration, it was fairly obviously a wreck!
And besides if I can do it, it can't be that hard 8)
I think in a way it's easier to start again than try to do localised repairs anyway.
Wed Mar 19, 2008 11:34 pm
Tim Rowe wrote:
..It's looking almost new! :D
Thank you, but that's only because most of it is new :roll:
Wed Mar 19, 2008 11:36 pm
West wrote:
just noticed its a flat floor chassis as well
Yes that produced a bit of head scratching when I tried to fit the seats, I got a pair of Corbeau Alpines for my birthday!
My adjuster rail design went straight in the bin, even with the seats directly on the floor there's only just enough headroom and I'm on'y 5'8".
I've leaned them back a bit and it's OK now...just.
It's made worse because I'm fitting a cage, but there's really not a lot of room in a Coupe is there !!
Just a couple more weeks work then :P
You think that long? I though it might be finished by the weekend :(
Wed Mar 19, 2008 11:43 pm
Ahh, I think not, a long way from deepest Dorset, don't really do straight lines anyway :D more a bendy sort of person :?
Be interesting to see how it goes though.
Thinking about that, what's the traction like? Do any of you run an LSD?
Wed Mar 19, 2008 11:50 pm
You would think so, but actually I've removed so many bagfulls of rust, muck and soundproofing not to mention the second layer of steel 'welded' over the rust, that I think in fact it's still lighter !
I also removed the roof spoiler...that turned out, like the arches, to be made of solid filler, it weighed an absolute ton !!!
Ah, that could be a problem, that's exactly what I was planning on doing.
Do you know who said that, and why??
Wed Mar 19, 2008 11:57 pm
Traction is pretty good, depends how much of an animal you are and how much power, think only myself and ken haywood run an LSD. but mine is a little different for obvious reasons. but generally you will find you have more traction than you do on the road as its a prepared surface especially if some of the drag cars have been down and laid a nice bit of rubber down.
It must be tight in your coupe, glad mine has the seat pans dropped as im 6'2 never would fit with a flat floor. especially when i put my crash helmet on.
Thu Mar 20, 2008 11:01 am
Yes, my son's quite large, also about 6'2", it looked very funny the first time he sat in it. His head was out of the sunroof, looked like he was sitting in a toy car!
Thu Mar 20, 2008 11:41 am
:lol: I`m glad i`m only 5'9" ish!
Dino- nope its not put me off, i`m visiting Phil (Pantera) off the forum this weekend to pick up my own bundle of pain and scrapped knuckles up.
Thu Mar 20, 2008 3:14 pm
Excellent, do post up some pics so we can all go oooohhhh :lol:
Thu Mar 20, 2008 8:25 pm
Dino,
It was a company that make cages, can't remember off the top of my head but i'll check when i get home on Sunday. It may be worth checking in the RAC regs before you get too far, i intended to do the same as you although i've no motorsport intentions at present :roll:
Edit: Quote fixed WEST
Fri Mar 21, 2008 1:35 pm
:lol: Keep an eye out today (lunchtime ish) for a post on my own project- i took quite a few pictures before it was hidden away in the garage.
Looks like i`m going to be busy for a while! and i may have to get friendly with a local welder, or learn a lot.
Thu Mar 27, 2008 10:52 am
Well a bit more progress.
Fitting the pedals, so I could work out seat and wheel positions.
More prep work on the body, it's now about the right shape and I've lost the wing and arches.
The cage is complete and fitted, I've tried to follow the MSA guidlines as much as possible but I just didn't have room for 2 roof bars without lowering the floor which I don't want to do.
There's going to be little enough ground clearence anyway.
I've decided to run the steering column through the front brace and also use it as the lower dash support.
And a milestone reached...I've made it onto page one of the build manual!
The body is now bonded onto the tub. :P
Thu May 08, 2008 11:23 pm
Nice work Dino, i like your cage 8) What do the rules say about the column and dash rail thing :?:
Thu May 08, 2008 11:51 pm
