Does your rear clam catch on the brackets?
Spider
Joined: Sat Oct 22, 2016 12:41 am Posts: 154 Location: Brisbane Australia GTM: Spyder
Opening and closing the rear clam on my Spyder was a 2 person job to avoid it catching on the lowest mounting brackets. I made these little guides on a 3D printer. Material is ABS - weigh 14g each - solves the problem. If anyone is interested I can upload an *.stl file so you can get them printed locally. Before After
Wed Feb 22, 2017 11:56 pm |
Re: Does your rear clam catch on the brackets?
That is pretty cool. I've not had any trouble with my rears but I often flick off the spire nuts from the bottom fixings on the front when opening. I might try something similar to avoid having to grovel around on the floor looking for the errant spire nut!
Thu Feb 23, 2017 8:23 am |
Elansprint
Very neat but as above I have more trouble with the fronts Ian
Thu Feb 23, 2017 8:41 am |
yazza54
My rears are fitted from behind, so there's a square hole in the inner panel if that makes sense, so it sits pretty flush
Thu Feb 23, 2017 11:24 am |
sidewinder
I found the originals to be a bit flimsy & replaced them with solid metal blocks with a threaded hole. Attachment:
Thu Feb 23, 2017 2:47 pm |
ray-spyder
Joined: Fri Jan 30, 2015 11:10 am Posts: 32 Location: Ss16
looks good can i have the stl please?.
(i have a fog light surround file stl if anyone fancy's it.)
Thu Feb 23, 2017 3:07 pm |
Spider
I couldn't upload the file (what file extensions will this site allow?) so here is a link to the file on my dropbox account. https://www.dropbox.com/s/5mzwi14fdf6nbqf/Clam%20Guide%20B.STL?dl=0
Fri Feb 24, 2017 4:39 am |
terjea
Joined: Mon Aug 09, 2010 8:56 pm Posts: 58 Location: Bergen, Norway GTM: Spyder
Fri Feb 24, 2017 8:56 am |
yazza54
Look nice but assuming they're a push button to release is that not tricky only having one pair of hands?
Fri Feb 24, 2017 9:09 am |
terjea
Quote: Look nice but assuming they're a push button to release is that not tricky only having one pair of hands? Your are never alone in a Spyder... You need to do one side at a time with a little care, so its not perfect. T
Fri Feb 24, 2017 10:21 am |
ray-spyder
Quote: stl file so you can get them printed locally the beauty of 3d printing. you can have a file send to you from halfway around the world and have it on your desk in 2h .
Fri Feb 24, 2017 1:38 pm |
librakv6
I did the same as yazza's made a square hole and mounted from the back, also cut down the flange on the rear clam, the clam shuts without touching the tub at all, I think this is the cheapest option Jamie
Fri Feb 24, 2017 10:03 pm |
ray-spyder
Quote: I think this is the cheapest option it is a common misconception that all 3d printing is pricey this print cost me 21p a part. so i may as well give it a go .
Wed Mar 01, 2017 8:52 pm |
Spider
Can't speak for all 3D printed plastics, but the ABS I used responds well to a brief dip in acetone or paint thinners. This melts the strands to produce a stronger, smoother part. In my case, I sanded the parts smooth, then dipped them.
Thu Mar 02, 2017 1:29 am |
