It is currently Fri Mar 29, 2024 7:58 am
[ 5 posts ] |
Larkingabout
Joined: Tue Jun 03, 2014 7:34 pm Posts: 71 Location: Tonbridge Kent GTM: Spyder
Drivers door
Just got back from a French trip in the Spyder and due to the jolting it and me got I now can't open the drivers door. Firstly it got a bit difficult, then I could only open it from the inside now not at all. When I could open it, the door seemed to have dropped a bit and was loose. I presume the hinges are adjusted from inside the door and I have the original hinges so it would appear. Also the central locking actuator seems to be working so I presume something has fallen apart inside the door. Will take the card off and have a look, it feels like when you pull the internal lever it feels as if it is not connected to anything. Just got to get it open to work on it!! Any thoughts would be appreciated.
Mon Apr 13, 2015 6:51 pm |
sidewinder
Re: Drivers door
Original type hinges are adjusted at the top mount outside the door. Bottom one can be moved but door needs lifting off 1st I think. Might just be a control rod jolted off or something worked loose. Also, checked the lock fixing bolts on end of door?
SAS
Mon Apr 13, 2015 8:52 pm |
Larkingabout
Re: Drivers door
Thanks for that I shall get out the spanners and screwdrivers when I get a moment this week.
Mon Apr 13, 2015 11:27 pm |
Re: Drivers door
Sounds like the connection bar between the handle and lock has popped off certainly, funny enough my coupe has just done the same thing and it is stationary in the workshop and has been for a couple of years!
Tue Apr 14, 2015 3:48 pm |
Larkingabout
Re: Drivers door
Had a look and sorted it. The cable had detached and the lock was loose. Got all sorted within 30 mins!!!
Tue Apr 14, 2015 6:33 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 7 guests |
