It is currently Fri Feb 21, 2020 8:26 pm
First gtm coupe project
Post First gtm coupe project
Greetings
I have just purchased my first gtm coupe. I found it on this very site!! It's not quite a complete car but I do have a 1340 mini that will be donating it's engine and any other bits that I can use. Main things I can think of are rear screen, loom( Colin was the previous owner from Nottingham and he told me that autosparks can still supply new ones). Master cylinders and what do I do with the pedal box? And does anyone have a build manual for one ? I've found the pdf version?
(Expect to see a lot of me on here asking questions)
Sun Jun 19, 2016 10:30 pm
Post Re: First gtm coupe project
Build manuals
https://dl.dropboxusercontent.com/u/12539652/Build%20Manual.pdf
https://dl.dropboxusercontent.com/u/12539652/GTM%20Manual%20-%2089.pdf
different versions so pick and choose what bits you need
Mon Jun 20, 2016 10:54 am
Bigphil wrote:
Greetings
Rear window you make yourself, warm "polycarb" and cut to shape.
Loom, depending if you like spaghetti build it to suit, use trailer cable and connectors as needed.
Pedal box/cylinders are cut down mini items, instructions in the manuals.
Mon Jun 20, 2016 11:00 am
Thanks very much. What happens with Iva/ sva testing. I have a v5 for the gtm?
Mon Jun 20, 2016 11:10 am
If the V5 says GTM then you are fine, no testing needed.
Mon Jun 20, 2016 11:51 am
Fantastic. Thanks ken. But before I start I have to fix the power steering on my Audi. As it died right outside my house with the trailer and gtm attached. And my spare car is 35 miles away from me. Testing times indeed.
Mon Jun 20, 2016 12:15 pm
The more cars you have the more problems you have :roll:
Tue Jun 21, 2016 8:07 am
This is very true Kano. That's why my corsa project is being finished and sold. The mini will lose its heart and a few other bits for the gtm And I may part with my bmw and stick with the Audi once it's fixed or vice versa!!
I think you bought your car from the same person as me from what I can make out. Colin west.??
Tue Jun 21, 2016 9:05 am
