Re: later type rear arms.
You could try RDM the designers of the newer arms
http://www.rdmgroup.co.uk/I'm still looking for the proper bushes.
Alternatively it should be possible to convert the original arms to use a similar type bush. I thought about this after having got and fitted the new type myself. You'd need to design new brackets, RDM one is basically a U section of steel with webs across and holes drilled for the bush bolts. Then I would cut off the threaded rods from the Land Rover TREs and weld them to pieces of tube (maybe with small webs for strength) into which the bushes would go. Note, I would use BMW bushes which are 57x45x12mm (RDM are 57x40x12mm) as they are readily available.
RDM used cam bolts on the outside bushes to allow for adjustment, but with this mod you could just use the original adjuster nuts that run on the threaded rods.
So long as you keep the pivot points in the same positions relative to the car's bulkhead I see no reason why this wouldn't work.
