Joined: Fri Sep 14, 2007 10:34 pm Posts: 883 Location: Somewhere between VTEC and redline
 Re: Marty's Coupe
Top work
i see you have a couple of rear diagonals going back on your roll cage, will these pass under the bodywork or are you going to have to go through the rear window?
_________________ IF wile e coyote had a GTM he would have one with Nitrous too! watch out road runner! The First GTM into the 11s, PB 11.00 @ 124.98 Mph on A048 tyres!
| Sat Feb 28, 2009 6:01 pm |
GTM-Marty
Joined: Thu Feb 12, 2009 10:28 am Posts: 34 Location: Carrickfergus
 Re: Marty's Coupe
I think it should go through the rear fibreglass bulk head. I'll have to cut it a bit, but wthat is an area to be looked at for sure. The original GTM lower arms for the rear. What bushes do people use in them, same standar Mini ones on all three pivots?
| Sun Mar 01, 2009 8:47 pm |
SportsLibre
 Re: Marty's Coupe
You need to remove all the rubber you can from the rear end or you will find the car steering itself all over the road.
| Mon Mar 02, 2009 10:16 pm |
The Jones
Joined: Sun Sep 30, 2007 4:41 pm Posts: 23 Location: merthyr tydfil, south wales
 Re: Marty's Coupe
Been doing my cage today, the backstays will pass under the bodywork if you move the main hoop forward a few inches. Still managed 40 degree angle on the backstays and joined the main hoop just on the start of the bend, for taller people (main hoop closer to bulkhead ) you should still be able to have 30 degrees (min in blue book) and join the main hoop just below the bend ( blue book states as close to out side of the bend as poss ). Will post some pics later this week and some of a rally coupe I used to co-drive in.
_________________ Building vaux 1.6, 16v for hill climbing, tracking,playing etc
| Mon Mar 02, 2009 10:41 pm |
 Re: Marty's Coupe
I knew there must be somthing that would be close to working and being legal in the blue book, as i knew you could move the tube down to the bottom of the bend, i think one version interpetation of the rules was no more than 6 inches down from the top of the roll bar, just look at the lotus elise when they are racing i dont remeber seeing any reaward diagonals on them but one forward one to the bottom of the passenger footwell. Gives me hope for when i get around to sorting my full cage out
| Mon Mar 02, 2009 11:26 pm |
minitici
Joined: Sat Jul 26, 2008 9:45 am Posts: 68 Location: Scotland
 Re: Marty's Coupe
Cages in Elises may have a rollbar certificate i.e. the cages have been certified by the manufacturer / designer to meet set criteria. In this case they do not necessarily need to look like the 'standard' blue book roll bars. It would be very difficult (expensive) to have a one-off rollbar certified....
_________________ 1967 Cox GTM; 1970 GTM Coupe (One is never enough!)
| Mon Mar 02, 2009 11:42 pm |
GTM-Marty
 Re: Marty's Coupe
Brief update, After suffering from cash flow problems and a change of garage I have again been able to turn my attention to the project. Chassis was shot blasted, Zinc primed and powder coated last week so now begins the job of putting it back together. Spent Sunday morning reattaching the front subframe, hope to get the rear on later in the week so it's a rolling chassis to tinker with. As you can see from the photos i've decided to go for a very unique colour..............
| Mon Jul 27, 2009 2:13 am |
turbocox
Joined: Mon Oct 01, 2007 7:25 pm Posts: 508 Location: milton keynes
 Re: Marty's Coupe
_________________ THE WORLD'S FASTEST 'A' SERIES COX GTM 1/4....13.502 @115mph MITP 08
| Mon Jul 27, 2009 5:06 pm |
