It is currently Thu Jul 29, 2010 2:36 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
Marty's Coupe
Post Marty's Coupe
Hi All,
I've inherited a 1982 GTM COupe from my Dad. He used it for competition for a number of years before giving it to a fella to store in a farm shed, however the guys never put it away and as a result it lay in a field for 3 years. The rust had set in quite badly when he got it back and he could never find the time to get it running again. He did strip it to its component parts a couple of years ago and decided the job was just to time consuming, so he gave it to me. I've been working on Mini's for a number of years now so thought this would be a good little project to keep me occupied. I've attached some pictures below of the car in its hay day doing hill climbs in Northern Ireland and sprints at Kirkistown and Nutts Corner race tracks.
Thu Feb 12, 2009 11:05 am
Post Re: Marty's Coupe
So now she is lying in my garage with most of her parts and i've completed the welding of the chasis. I'll be talking it to be shot blasted and primed to remove the rust and hopefully make her weather proof for many years to come. Probably get the chasis powder coated while i'm at it and keep her the same red, for old times sake. I have 2 competition race engines but I think I'll use the smaller 998cc road engine I have to start with. I would love to drive her on the roads for a few years before upgrading things for competition use.
I've posted in the Coupe section as the car is missing a number of components, mainly a wiring loom and fuel tank. Can I use standard mini parts with a bit of modification or does anyone have any spare GTM parts which are no longer required?
The pictures below are about 6 months old and show the chasis resting against the garage wall and the race engines. I'll put up fresh ones later this week. Would like to have her back on the road for the August bank holiday.
File comment: Race Engines
File comment: Chasis
Thu Feb 12, 2009 11:12 am
Some Pics taken today, I stuck the fibre glass main section on just to get a feel for the fact it is really a little car. Taking the chasis to shot blasted, primed and powder coated before the end of the month! :D
The wee mini is not a donor car, my run around for a number of years and now needs a bit of welding work done on the front end, rusting in the usual spots!!! A panel, front wings under the lights etc.
File comment: Front Exterior of Chasis
File comment: Rear Exterior of Chasis
File comment: Rear inside of Chasis
File comment: Front inside of Chasis
File comment: Bonnet
File comment: The engines
File comment: Boxes of Bits
File comment: Subframes
File comment: Reggie the mini, waiting his turn for MOT work.
Thu Feb 12, 2009 9:51 pm
Why have you got 2 chassis? :shock: :roll: :lol: :lol: :lol:
Are you planning another Honda transplant aswell?
THE WORLD'S FASTEST 'A' SERIES COX GTM 1/4....13.502 @115mph MITP 08
Thu Feb 12, 2009 11:12 pm
2 chassis?
I can see 3 front subbys but only one chassis :?
It's got to be frunky.
Fri Feb 13, 2009 9:41 am
In the forth picture from the very top you see one against the wall and one in front of it on the floor :shock:  :mrgreen:
Fri Feb 13, 2009 10:08 am
Aren't you the sharp eyed one? :shock:
The green one has the same chunks chopped out that I had to for the 4age - i wonder........
Fri Feb 13, 2009 10:37 am
I spotted the second chassis too :mrgreen: Then lo and behold within a couple of hours Stuart posts the question :lol: :lol:
Phil, the brackets in the footwell are for mounting the front part of a full cage.
Fri Feb 13, 2009 10:45 am
The second chasis is completely rotten. We got a hold of it for some measurements as the chasis we are using had been rolled through a hedge. So had to ensure it measured up right before we started work. They sturdy things, slightly bent on the drivers rear suspension arm but other than that the chasis had not bent at all!
The chasis against the wall could be used to build a 2nd GTM (with a couple of months of welding work), I have enough parts to build about 3 minis so parts wouldn't be a problem. Missing the Glassfibre body for the second one though and dunno were I could get a hold of one, except keep a keen eye on eBay.
Fri Feb 13, 2009 10:55 am
Yeah, i'd sort-of come to that conclusion myself. :D :D
Is that why your back end is chopped off? Or are you going for the Ginetta G15 look???
Fri Feb 13, 2009 12:33 pm
The back end is sitting on the floor. We have one complete decent body shell. The back end was chopped off and will be attached using the same clips you see on single seaters. allows quicker and easier access to the engine bay when the car is complete... so I am told!
Fri Feb 13, 2009 2:39 pm
Both Chassis look pretty solid to me from the pictures. (these are not manufactured any more, I had a quote from Premo designs @ £2000+VAT) :shock:  :shock:  :shock:  :shock:   :shock:    :idea:  I wolud hang on to it if I were you :wink:  it will be needed again, or  once you are bored with the a series ..:roll:  :roll:  :roll:    I've  spent enough money, to know :roll:  :roll:  .  I bought the last chassis manufactured by GTM which had been passed to Premo when they bought the rights (it was old stock  :wink: so a cheaper price was agreed)  :mrgreen:  :mrgreen:
Fri Feb 13, 2009 3:33 pm
Do you mean dzus fasteners :?: :?
Fri Feb 13, 2009 7:55 pm
Indeed, couldn't remember the name of them!
Mon Feb 16, 2009 10:27 am
Some new pictures,
I've spent the past 2 weeks sprucing up the subframes and making them as rust proof as possible. Also rebuilt the back brakes and built the suspension in the front subframe.
File comment: My 'Helper'
File comment: 'Rear' subby with Red oxide Primer, this is now black like the other one.
File comment: rear lower arms with a lick of paint
File comment: Rebuilding the rear drums
File comment: Complete rear drums
File comment: Paint job finished
File comment: Front subby on the bench
File comment: front suspension arms
File comment: Chassis with Rollcage, just to see how it fits.
Sat Feb 28, 2009 3:18 pm
