Re: MGF Cable Change Cable Lengths
Your measurements seem about right I used standard mgf cables and made a threaded tube with two female threads screwed the end off the original cable screwed my extender on to the cable and threaded bar in the other end and put the end back on.
Job done, hope the makes sense.
You will need to use the 1.4 metro engine mount on the bigger engine.
Seem to remember that I also needed new gearbox mount and exhaust bracket.
You also fit a engine steady to the 1.8 engine at drivers side as the one to the r65 gearbox no longer fits althought I did make a bracket up and have both on my car.
Matty
