It is currently Wed Jul 17, 2019 6:12 pm
Old K series head bolts wanted
Post Old K series head bolts wanted
Hi all,
Does anyone have 2 old k series head bolts they don't need? I need a couple of old ones to cut down and make cylinder liner clamps with before I begin my engine rebuild.
To make it easy I could arrange for my hermes to call and pick them up?
Jamie
Sat Jan 30, 2016 11:51 pm
Post Re: Old K series head bolts wanted
Jaykart1227 wrote:
Hi all,
Jamie
Maybe a daft question, but aren't you taking 10 of these out when you take the head off?
Sun Jan 31, 2016 11:26 am
:lol: Not a daft question at all.
I'd like to cut down and modify a couple of old bolts in advance of removing the head as knowing my luck I'll acedentially move the the crank and break the liner seal before I have chance to hold everything down :roll:
Sun Jan 31, 2016 12:28 pm
http://www.gtmdrivers.com/forum/flywheel-locking-tool-t3216.html
Wouldn't be a bad idea to lock the flywheel. Not sure how else you'd get the crankshaft pulley bolt undone anyway? In the thread linked here you'll see that with a very small mod you can use the GM locking tool from Draper that you can get for peanuts. The amazon link I posted then has gone up a bit but I bought mine for only £1.36 delivered!!!
Sun Jan 31, 2016 10:49 pm
Good tip. Just ordered one from eBay, cheapest I could get was £3.97 :D
I'm still after the head bolts though as I want to replace the crankshaft oil seal at the flywheel end as well.
Mon Feb 01, 2016 8:36 pm
You could do the crank oil seal either before you've taken the head off or after you've put it back on again. Not sure why you want to alter a bolt to make a liner retainer - just use some pipe and big washers? Like this:
Mon Feb 01, 2016 10:09 pm
That's probably an easier option to be fair. I'll get some tube (and me coat) :lol:
Mon Feb 01, 2016 11:25 pm
