Re: Paul's libra
catsam wrote: https://www.ebay.co.uk/itm/383847922285 Not tried that one but others have said it works and definitely a simple solution if it does. I think I already mentioned I went with some chunky power resistors but basically the same thing.
Thu Dec 30, 2021 1:22 pm |
catsam
Joined: Thu Jun 27, 2013 11:32 pm Posts: 492 Location: Norfolk GTM: Libra
Re: Paul's libra
Quote: Not tried that one but others have said it works and definitely a simple solution if it does. I think I already mentioned I went with some chunky power resistors but basically the same thing.
hi sanzomat I read your post and yes it's the same thing just in one package I have stopped working on the wiring for now I need to get the middle part of the loom from the car so I have started to work on the inside trim panels the wether is cold and wet so can't get outside for now All the vinyl is cut for the inside panels and just needs to be stuck on the panels. which I will do closer to the time when I fit them back into the car. I'm not having much fun taking the old glue off the panels I have also changed the inside color from gray to black but I don't know if this will be too dark as I'm going to be putting a black carpet in the car
Fri Feb 04, 2022 6:58 pm |
catsam
Re: Paul's libra
I have taken the front suspension of the car and stripped all the parts I will send the Coilovers to gaz for servicing the springs I have given them a clean and sand. they have come up very good so I will give them a re-paint (with flexible paint). I have stripped down all the front brake Calipers I will refurbish the Brake Caliper with new seals and Pistons and paint (MUST BE RED ) the suspension is all looking good. I have all new bolts and bushes that should go back together a lot easier than it came off the car just needs some paint or powered coat
Sat Feb 19, 2022 4:16 pm |
catsam
Re: Paul's libra
I have started to strip down the back suspension I have taken the gaz suspension off and sent it back with the front ones for service and fitted a bar to stop it from collapsing I need to take the top ball joint off the hub I have read that this can be very tight so got one of these (46mm Slogging Ring Spanner Box End Striking Wrench ) I will give it a go and see how it works the hub and the top ball joint are off the car and the slogging spanner worked very well
Sun Mar 06, 2022 8:37 pm |
sidewinder
Re: Paul's libra
FYI, might be adaptable for your spanner. post19506.html
Sun Mar 06, 2022 8:43 pm |
catsam
Re: Paul's libra
i like your solution for the spanner slipping from the nut download/file.php?id=1346
Sun Mar 06, 2022 9:00 pm |
Spider
Joined: Sat Oct 22, 2016 12:41 am Posts: 154 Location: Brisbane Australia GTM: Spyder
Re: Paul's libra
Yeah good tip - thanks.
Sun Mar 06, 2022 11:09 pm |
Re: Paul's libra
Looks a fairly stiff set up there giving a spring rate of infinity/inch
Mon Mar 07, 2022 1:10 pm |
catsam
Re: Paul's libra
I had fun today with my boy trying to get the rear suspension from the car the build manual says ( The rear suspension mounts directly to the monocoque. Loosely mount all four mounting brackets using Ø6mm socket cap head screws ) it forgot to say you can't get to the nuts to undo them
Thu Mar 17, 2022 10:12 am |
catsam
Re: Paul's libra
I have made some new brackets for the brake lines out of some stainless-steel
Sun Mar 20, 2022 5:23 pm |
catsam
Re: Paul's libra
I have been taking all the suspension parts of the car and removing the old paint I'm starting to collect a lot of parts in boxes
Sat Mar 26, 2022 6:31 pm |
sidewinder
Re: Paul's libra
Label everything!
Sat Mar 26, 2022 7:19 pm |
catsam
Re: Paul's libra
I have got the engine removed from the car there is not much left on the car now some pipes and the wiring loom the exhaust manifold is bad its not that flat so ebay for a new one
Sat May 07, 2022 9:12 am |
catsam
Re: Paul's libra
now I have the engine and frame removed from the car there is not much left just some pipes and the wiring loom the old frame it's not too bad. I have a new one that was with the car
Sat May 07, 2022 11:31 am |
catsam
Re: Paul's libra
Sat Jun 04, 2022 6:48 am |
