It is currently Fri Jan 18, 2019 1:31 pm
Coil overs on the bottom arm ? here they are
Post Coil overs on the bottom arm ? here they are
Hi , i mentioned that my old racer has coil overs fitted which go to the bottom arm , some of the tower is cut back to allow for rising rate , here is a pic, not really sure about whether it will affect the bottom ball joint as someone said in projects? I do know it has been like this for a very long time !
What do you think
cheers simon
Wed Jul 21, 2010 7:13 pm
Post Re: Coil overs on the bottom arm ? here they are
those are motor bike shocks as they have progressive springs
WJG AUTO'S
thistle industrial estate
cowdenbeath
fife
ky48lp
07967945610
wjgautos@live.co.uk
Wed Aug 25, 2010 10:27 pm
yes they look like bike shocks , i never got to see how good/bad this arrangement was as the car had suffered such corrosion in the body it was undriveable, but i thought the car looked like it had been sorted very well with most things being uprated , it has been said that the ball joints suffer but my knowledge here is limited , i have however wondered what if a bracket was made that went between the ball joints with a coil over mounting in the middle where the old drivshaft would of been , as the cv is machined down and is not in the way ? just thinking ...... :lol:
Fri Sep 03, 2010 3:15 pm
Thats a big spacer on the front 1"?? was that for clearence or wrong offset rims?
Fri Sep 03, 2010 5:49 pm
Hi , all i know is this was a wide gtm , a heerey i think , i think the arches stood 5" from the body , even the headlights were fitted slightly further forward , i really must fund some pics .....
Sat Sep 04, 2010 11:43 pm
have a look at my coupe spaceframe in the forsale its a wide 1 off with coilovers also if you need wishbones made i do it for a job thanks wullie
WJG AUTO'S
cowdenbeath
fife
ky48lp
07967945610
wjgautos@live.co.uk
Sat Sep 11, 2010 9:44 am
