It is currently Fri Apr 19, 2024 5:48 am
Post new topic Reply to topic  [ 391 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27  Next
Cox GTM ('67-'68)
Post Re: Cox GTM ('67-'68)
I have two breathers. One on the timing cover and one on the rocker cover. Though I have some crancase gas, not too much at all.
Sun Aug 22, 2010 1:10 pm
400 kms is not that far, i would have thought 1600 kms to run in a rebored engine.
6500-6800 is probably realistic for the cam.
There are much more modern single wound springs available these days that would do a better job than the old skool double springs and be kinder to the cam.
Sun Aug 22, 2010 1:39 pm
Try coming down to 1.3 bar front 1.6 bar rear, but do this change only nothing else to see how it feels.
You might find this works better. It is close to what I run and simular to what stuart runs [turbocox]. I know It made a huge differance on mine reducing the fronts to this level made the car less nervous. It will make the steering a little heavier, but you will get use to it.
Sun Aug 22, 2010 1:48 pm
CamelotR wrote:
The car holds the line firm, though it is not willing to get back to straight. It has no oversteer, no bumpsteer. But it fast corners, when I step on the accelerator, it becomes uneven. Not much, but I can feel. It is "nervous".
Have you removed all of the rubber from the rear, any rubber bushes left are likely to deform and steer from the rear on power.
Mon Aug 23, 2010 8:27 pm
Maybe. If I do not succeed with the tyre pressure/toe-in changes, I will search in the suspension.
Mon Aug 23, 2010 9:35 pm
I have rechecked the suspension throughly, and it turned out that after the castor adjustment, the front suspension has developed some bump steer :? (I thought that the castor was right, but it wasnt, soo slightly missplaced the rack).
Is there any known solution to cure it? I have toe-in on bump (soo have to raise the track rod end somehow).
Tue Sep 07, 2010 7:54 pm
The original Cox GTM mounted the steering rack on the front bulkhead.
Later GTMs mounted the rack on the back of the front subframe on special brackets.
Wed Sep 08, 2010 11:04 pm
You will need to lift the steering arms. This is what you do on the racing minis for bumpsteer.
Alex
(Gulf) GTM Coupe
Thu Sep 09, 2010 8:00 am
I have my steering fborlted to the subframe as I wanted to get the steering arms inline with the rack.
Lifting the arm? How? Simply by fitting spacers? Sounds a bit hard...
Thu Sep 09, 2010 11:13 am
Its corrected with spacers under the steering arms.
If you do a search on the mini marcos forum you will see what i am talking about!
Mini Marcos Forum > Sport > Class win
And e-mail John Dickens Iam sure he did it on his coupe
Alex
(Gulf) GTM Coupe
Thu Sep 09, 2010 5:03 pm
http://www.minimarcos.org.uk/cgi-bin/forum/Blah.pl?b=SP,m=1191271779
Thu Sep 09, 2010 7:26 pm
Cheers Ken!
(Gulf) GTM Coupe
Thu Sep 09, 2010 7:59 pm
Great thanks!
I have ended up doing this with rather minimal modification to steering arm gave good results.
... I am still unable to upload a pic :( ...
Soo I have angle skimmed steering arm to raise the end about 10mms. Now my bumpsteer is about 1mm on the whole suspension travell, and 0.5mms on the "normal travell". I think it should be ok for the road. Or?
Thu Sep 09, 2010 9:16 pm
By the way, I have fitted the front windscreen today. :mrgreen:
It was a great pain in the back as we did not checked it while making the chassis, but it turned out to be not that bad fitting. Just one part was awfull: the lower corners, especialy the left hand side. Did any of You experienced the same?
Thu Sep 09, 2010 9:23 pm
I have corrected the suspension geometry, but the ride is still not perfect. I think the rear steering arm pickup point on the subframe is a bit weak and flexing. How was it done on later GTMs?
Fri Sep 17, 2010 5:49 am
