It is currently Fri Mar 29, 2024 7:16 am
savage switchs
Post savage switchs
hi all, right im going to swop the ugly big rover switchs in the libra for somthing a little more asthetically pleasing,
has anyone fitted savage switchs, they seem to have loads of terminals at back and as im not good with electrics, as any one got a simple colourcode wiring diagram for the rover switch so i can easily identify the wires already there ,
even better if you have detailed diagram for savege to rover ,
Mitch
Thu Apr 11, 2013 3:32 pm
Post Re: savage switchs
I have the savage hazzard switch on my mini, it's quite straight forward. I can try and find the diagram if you are stuck.
Thu Apr 11, 2013 6:21 pm
Hi Mitch,
Did you get the switches fitted?
http://img.photobucket.com/albums/v12/modifiednovas1/other/SavageHazardLightSwitchWiringDiagra.jpg
Is an image of the papaer work that came with my switches.
Really easy to fit but if you get any more questions feel free to ask.
I have yet to find a connector that goes onto the back of the switches so at the moment the best thing I have found for the jobs are these:
http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalsnonins/noninsblades.php
Use the blade terminals with the insulated cover.
I think they are 2.8mm wide but I will double check when I get home.
If you can find a connector housing let me know as I would swap all mine over.
Miguel
GTM Libra
K1 Attack (Work in progress)
Thu May 09, 2013 7:05 am
that diagram far better than the one i had thanks Miguel, but anyone know the the colours for the std A/c switch so i can swop over,
not seen any plugs for the backs so was going to use spade terminals ,
Mitch
Thu May 09, 2013 5:06 pm
