It is currently Wed Apr 24, 2024 7:07 am
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2, 3, 4  Next
Rossa Type R build
Post Rossa Type R build
Hi everyone,
been meaning to start a build thread for our GTM project for quite a while
Here is a Picture of the car before we picked it up
As soon as we arrived back to the garage first thing we needed to do was completely strip the car apart
Unfortunately we arent currently able to find any photos of us working on it up until this point here.
Before fully welding the cage we test fitted it one last time just to make sure it was as good as possible and
if any add ons were needed adding them in, at the same time
we were also fitting the standard civic type r ep3 subframe to see how it fitted
this was when we were in the midst of fully welding the cage and then prepping it for spraying
again unfortunately in between prepping the cage for spraying and where we are at just now we have no photos for the
majority of the build as our camera was away getting fixed.
this is how things look at the moment underneath the bonnet, custom built fuel tank designed by ourselves as the original
mini tank was keeping the centre of gravity to high and was not using the available space well enough, the swirl pot is
one from jjc race and rally that has been cut and re fabricated to fit under the bonnet but it will be replaced sooner
rather than later with a custom built slightly fatter one as we have had quite a few problems with it, we have a high
pressure pump feeding off of the swirl pot and a low pressure built into the bottom of the tank.
Here is what the inside of the car currently looks like, wooden dash basic shape is to be finished once all wiring is sorted
then we will make the finished item with carbon fibre, as you will be able to see things such as gear lever postion, hydro handbrake
position and others are still to be finalised and we still need to find a suitable place for the battery to go, probably in the front.
This is how we are starting the car at the moment, wooden blocks are a great hand when building projects
And here are some pictures of its current entirety as im sure you can see we still have a lot to do, but we have
got the engine going and we are just waiting on modified brake carriers before we will be able to drive it up and
down the drive way to check that we are getting all gears and to sort out any little niggles before rebuild part 2
Like our page on Facebook as we have other on going projects and updates
http://www.facebook.com/MastertonMotorsport
Last edited by scottmasterton on Wed Nov 06, 2013 9:51 pm, edited 3 times in total.
Tue Nov 05, 2013 8:52 am
Post Re: Rossa Type R build
My gob has never been so smacked :shock: :shock: I look forward to seeing more detail of this one - it looks so well thought out. Superb - well done 8) (And doesn't that exhaust look just brilliant.... pity there ain't a 'smiley' for envy).
Tue Nov 05, 2013 9:44 pm
Good to see you have found your way here, DOes that now mean there are two K series Honda powered Rossas as IM sure I have seen a white one on you tube with a z cars influance in build
neil
Tue Nov 05, 2013 11:27 pm
yes neil it does, we actually got the exhaust system itself from z cars as it is what they used
themselves when building the other one and we think it is the same exhaust they use for
all of their type r engined projects, this gtm as im sure you can tell is being built for track
and hopefully rally usage so it is going to end up being substantially different. :D
Follow Us On Facebook
Wed Nov 06, 2013 9:56 pm
Good skills. :mrgreen:
Thu Nov 07, 2013 10:49 am
Thu Nov 07, 2013 6:25 pm
Got the engine started, not idling correctly because it has huge air filter and exhaust is so much different from standard with no cat, needs remapped soon, should be getting at least 240bhp after map,.
http://www.facebook.com/photo.php?v=608716892498698
Fri Nov 08, 2013 12:13 am
Is the wheelbase the same dimension as the car was originally? I ask this question from an MSA regulations/competition point of view
David
Land Rover Freelander 2
BRA 289 Cobra replica
Porsche 968 Coupe
Radical PR6
Fri Nov 08, 2013 7:56 am
David
David the wheelbase is exactly the same as the original car, the track however is obviously different
Fri Nov 08, 2013 7:37 pm
A good result
David
Porsche 968 Coupe
Radical PR6
Sat Nov 09, 2013 8:14 am
David Large wrote:
A good result
David
thank you :) what honda engine is it you have in your GTM?
Sat Nov 09, 2013 10:25 am
This is very close to how I would had considered doing a Rossa. There is a few different engined coupes but Rossas are much rarer.
Sat Nov 09, 2013 11:09 am
what would you do differently ?
Sat Nov 09, 2013 6:04 pm
scottmasterton wrote:
David Large wrote:
A good result
David
A 1600 twin cam not V tec - a D16 A9 engine, 150bhp on a rolling road
David
Porsche 968 Coupe
Radical PR6
Sun Nov 10, 2013 9:50 am
Does anyone know if the MSA would be fine with certain parts being changed to carbon fibre items as the car
is hopefully going to be used for rallying and is already made from fibre glass ?
plans are to make fixed perspex windows for doors but could we potentially make the doors themselves
out of carbon fibre?
also, we've yet to weigh the bonnet but we may make a carbon fibre item if we think it will drop us a couple of kilos
Tue Nov 12, 2013 10:25 pm
