Joined: Tue Jun 03, 2014 7:34 pm Posts: 71 Location: Tonbridge Kent GTM: Spyder
Wheel studs
Just had a disastrous morning. In the process of removing the front wheels I managed to snap a wheel stud clean through. Clearly I don't know my own strength. I am running standard rover alloys with no spacers and wonder if anyone knows the right length. There seems to be a number from 45 to 63 mm and knowing my luck I would get them too short. I presume rover hubs etc of some sort as the car was factory built. Also if anyone knows where to get them and some new nuts ( ? Rimmers) I would be grateful for a pointer. I also had a look and they seem to be a simple knock them out through the hub fixing so should not be too much of a problem but I might be wrong.
Sun Feb 15, 2015 4:39 pm
Sven
Re: Wheel studs
I think the standard studs are 45mm (m12 x 1.5). I bought some longer ones which are 63mm to fit to my rears (still to do!) as i'm using spacers.
Sun Feb 15, 2015 7:12 pm
Sven
Re: Wheel studs
After a quick search i'm not so sure now. Maybe 55mm...
Mon Feb 16, 2015 12:37 am
sidewinder
Re: Wheel studs
They are M12 x 1.5 x 45mm long. Have one here in front of me that I took off my Rover 100 hub. To check that's the length you have, your studs should stick out about 35mm from the flange face.
SAS
Mon Feb 16, 2015 1:21 pm
Sven
Re: Wheel studs
my links are for rear ones!! Are front & rear different? I blame it all on the cider i was drinking last night....
Mon Feb 16, 2015 8:20 pm
sidewinder
Re: Wheel studs
Not sure, but the Libra uses front hubs (Rover100/MGF) all round.
You'll be better off using a hydraulic puller to ease them out
Re: Wheel studs
Thanks everyone. They were 45mm long and I replaced two. One had broken and another had a bit of a damaged thread so whilst in the groove did them both.. Thanks for the advice re the wheel nuts they look a better bet than the ones I use with the captive washers.
