It is currently Sat Feb 22, 2020 5:48 pm
wiring loom.
Post wiring loom.
Just an update, I have managed to get a good early metro vanden plas complete wiring loom so I can finally lay out my rossa one and replace sections/ plugs that are damaged or missing.
Sun Feb 08, 2015 3:17 pm
Post Re: wiring loom.
Hi, can I just ask where you got the wiring loom from? I'm in a similar situation where all my loom around the steering column is damaged.
Thu Mar 12, 2015 7:23 pm
I came across it on ebay, paid £5 plus postage. I was going to adapt a mini wiring loom until I happened on this one.
Thu Mar 12, 2015 7:38 pm
You can adapt a mini wiring loom? Suppose that's only on the a series engine though right?
Thu Mar 12, 2015 7:40 pm
yer mine is a rossa 2 so a mini or pre k series metro loom is easy enough to adapt. There are usually looms from later k series metros/rover100 on ebay whick should have the correct plugs etc to repair a damaged loom.
Thu Mar 12, 2015 9:11 pm
Ah yeah I thought as much, thanks for your help. I suppose a new loom and wiring diagram to find the correct place is in order then.
Thu Mar 12, 2015 9:30 pm
