stewb
Joined: Thu Jan 23, 2014 10:26 pm Posts: 73 GTM: Libra
Limited Slip Diff?
Hi all, not sure how prevalent LSD's are in these cars. Have started leaning on mine a little & it's not difficult to get mucho wheelspin on hard accel.....I'm guessing that I don't have a slipper at the mo as the box is ZS from what I understand which never had a limited slip diff.
There was a factory option for an LSD on the PG1 fitted to certain T series Turbo engined cars & a few VVC ones too. These are the Torsen type so not technically the best for a RWD application but better than an open diff & a lot cheaper than the aftermarket options (Quaife ATB, plated etc).
Was thinking of getting a spare ZS box to build with a Torsen that I can swap over.
Does anybody have one in their car? Thoughts / comments?? Guess some of the Lotus sourced gearboxes may have come with LSD's from the factory?
_________________ ___________________________
StewB
'09 Libra K20 '69 TVR Vixen V8 '86 Capri 2.8i S ‘78 TVR 6200M-TT
Ex Libra V6
Thu May 07, 2015 10:50 pm |
Tim Rowe (1130)
Re: Limited Slip Diff?
Mine has a limited slip diff, but as I've never driven one without I can't really help. In the same way that mine has always had anti roll bars, so couldn't say how they help either. I'l have a look when I get time to see which one it is I have fitted.
_________________ Tim Rowe
Fri May 08, 2015 8:14 am |
stewb
Ok thanks.
Did a bit of reading around & they are apparently quite few & far between on elises, more prevalent on exige due to higher power/torque outputs.
I'll see if I can source one in anycase as I plan to get a ZS box to keep as a spare.
StewB
Ex Libra V6
Fri May 08, 2015 9:14 am |
ray-spyder
Joined: Fri Jan 30, 2015 11:10 am Posts: 32 Location: Ss16
hi stewb
i have a ZS box non lsd from a v6 libra + driveshafts and engine mount,transmission mount v6 loom all gtm type going spare if you're interested. i am in Essex just pay me wot you think there worth and i will be happy with that
thanks ray
Fri May 08, 2015 2:22 pm |
petesilcock
Joined: Wed Apr 15, 2015 4:52 pm Posts: 141 Location: Devon GTM: Libra
Does an LSD make the breakaway more sudden?
Sat May 09, 2015 6:28 pm |
stewb
Thanks Ray - I'll weigh up the options & see where to go next! Pete - think you're right in the fact that you'll get better straightline traction & general traction until the point of spin/slip at which point it's game over! We know all about that from our previous antics don't we
StewB
Ex Libra V6
Sun May 10, 2015 9:49 am |
Tim Rowe (1130)
Finally had time to check which mine is . Apparently it is a torsen lsd fitted to a rover 25 brm special edition gearbox. It is bolted to a 160bhp vvc.
Sun May 10, 2015 10:49 am |
stewb
Yep - that's the 'drop in swap' for the K, would have to bud the diff into a V6 casing for mine - no big deal.
StewB
Ex Libra V6
Sun May 10, 2015 8:17 pm |
