scottmasterton
Re: Rossa Type R build
octance wrote: Looking forward to seeing some footage when you get a Go Pro. Car is fantastic Thanks we will hopefully have one for our next test
_________________ Follow Us On Facebook http://www.facebook.com/MastertonMotorsport
Tue Jan 20, 2015 10:10 am |
scottmasterton
Update We definitely need to fix this haha. Think we'll have to make some sort of alloy plate to stop it melting when it spits out flames. We got an Ikeya sequential shifter off a friend to see if we can modify it to fit the car, which would be brilliant Also just got an LSD from gripper diffs, a 6.33 final drive from M factory which should give us a top speed of around 130mph with 15s or around 145mph with 17s and a baffled sump kit from CPL Racing to keep the engine running smoothly. Hopefully test it all soon, the car should be even faster
Tue Jan 20, 2015 10:21 am |
scottmasterton
We've been doing a bit of work in the cockpit over the past couple of days Had the Engine and box out, took the box with final drive and LSD over to Sitech and fitted the baffled sump kit Also started on the final shape for the bulkhead next on the list is to fibreglass the bulkhead, sort out the brake setup a bit more, fit power steering and then probably put it back together for the next test
Sun Feb 08, 2015 12:09 am |
It will be interesting if you get the shifter to work. Has been one of my thoughts how to make a sequential style lever to H pattern.
Sun Feb 08, 2015 11:37 am |
scottmasterton
WEST wrote: It will be interesting if you get the shifter to work. Has been one of my thoughts how to make a sequential style lever to H pattern.
Neil We should be able to get it to work providing prototyping goes well, at the moment it'll really just mean that we can't put it into the wrong gear and so we cant change down and blow it up haha
Sun Feb 08, 2015 10:34 pm |
scottmasterton
Thought I'd updated this thread ages ago We've managed to get some fibreglass work done on the bulkhead And try the K20 in an MGTF subframe for the rear Modifying it to fit the exhaust and for the engine to sit right Fabricating where the subframe connects to the rest of the cage Adding an analog rev counter to the dash display and power steering
Sun Aug 23, 2015 7:02 pm |
scottmasterton
Wed Dec 30, 2015 1:34 pm |
scottmasterton
Wed Dec 30, 2015 1:59 pm |
Ken555
I'm guessing DMT-RC as everything else comes in 18" only.
Wed Dec 30, 2015 6:16 pm |
scottmasterton
Ken555 wrote: I'm guessing DMT-RC as everything else comes in 18" only. Cant remember which ones they are but 15s and just for testing
Wed Dec 30, 2015 11:41 pm |
Ken555
They look like the old Maxsport RB5, I used to use on the Impreza.
Road legal slicks, made for interesting driving on a wet A823 !
Thu Dec 31, 2015 12:32 am |
scottmasterton
Ken555 wrote: They look like the old Maxsport RB5, I used to use on the Impreza.
Road legal slicks, made for interesting driving on a wet A823 ! Oh wait so they are haha
Sat Feb 06, 2016 7:35 pm |
scottmasterton
Just got the custom driveshafts from CPS drivelink really happy with how theyve turned out
Sat Feb 06, 2016 7:45 pm |
scottmasterton
We've been welding and strengthening the MG subframe a bit more And working away developing the quick release throttle cables
Sun Mar 27, 2016 2:56 am |
Why the change to MGTF rear end?
Sun Mar 27, 2016 11:21 am |
