turbocox
Re: Cumbrian coupe
lakelandgtm wrote: turbocox wrote: That loom looks a lot better than mine Did you make your own loom? No I didn't make it, but every time I touch it it still seems to have more smoke built up inside the plastic sleeving It just keeps coming out everywhere, How does it get in
Mon Sep 12, 2016 9:44 am |
turbocox
Re: Cumbrian coupe
Malcolm_Ball wrote: turbocox wrote: That loom looks a lot better than mine Can't You take it in to work and get someone to look at it ? It's not like the old days, your given so much work and so little time to do it in that you can't leave your work area, and nobody in any of the other departments want to help out as they don't have time either
Mon Sep 12, 2016 9:46 am |
Sven
Re: Cumbrian coupe
turbocox wrote: lakelandgtm wrote: turbocox wrote: That loom looks a lot better than mine Did you make your own loom? No I didn't make it, but every time I touch it it still seems to have more smoke built up inside the plastic sleeving It just keeps coming out everywhere, How does it get in You used to be able to buy jars of smoke to refill your wiring loom. Not sure if they're still available..........!
Mon Sep 12, 2016 11:44 am |
lakelandgtm
Joined: Fri Sep 02, 2016 8:39 pm Posts: 26 Location: Cumbria GTM: Cox/Coupe
Re: Cumbrian coupe
Are the tail brackets on the rear subframe needed for anything? Because the previous owner has cut them off. Attachment:
Thu Oct 27, 2016 7:59 am |
Re: Cumbrian coupe
Only if you want to use them to mount a silencer, that is what I used them for on my old old old setup
Thu Oct 27, 2016 10:37 am |
Steve Shield
Re: Cumbrian coupe
As West says some people use them to mount the exhaust although I prefer to attach it to the back of the engine so it all moves together. Also some rear facing RH gearbox steady bars mount to the bolt holes so avoid them -- other steady bars are available.
Fri Oct 28, 2016 8:49 am |
lakelandgtm
Re: Cumbrian coupe
Preparation on the tub is going well, alongside building the engine and subframes. The subframes and compomotive cx wheels have been powder coated in black, which you can see below, in my opinion they look pretty cool. We are currently working on fitting the pedal box, which should be completed soon. Attachment:
Wed Feb 01, 2017 9:14 pm |
flapjck1
Joined: Wed Feb 08, 2012 11:53 pm Posts: 31 Location: Poland GTM: Cox/Coupe
Re: Cumbrian coupe
Too much black
Thu Feb 02, 2017 12:08 am |
Elansprint
Re: Cumbrian coupe
Ben welcome to the forum nice little project you have there you may find your insurance is cheaper than a conventional car also good luck with the project Ian
Thu Feb 02, 2017 9:02 am |
turbocox
Re: Cumbrian coupe
Looking good, it'll be rolling before you know it.
Fri Feb 03, 2017 10:32 am |
lakelandgtm
Re: Cumbrian coupe
After a struggle the engine is in the subframe, and now onto the car. Pictures will be posted soon. But while we were fitting it we noticed that the clutch slave cylinder return spring hits the chassis, so we had to remove it. Is this normal? And is there a different way to attach the spring? Attachment:
Wed Feb 22, 2017 6:59 pm |
Re: Cumbrian coupe
I remember having a similar issue on mine when I was A series powered. I ended up profiling the arm around the pin to increase clearance. I did get a return spring fitted too.
Also think some careful positioning of the engine on the steady bars helped and having the engine fairly stiff made sure it never caught.
Wed Feb 22, 2017 7:46 pm |
kano nordie
Re: Cumbrian coupe
The early Cox build recommended the clutch arm should be bent a little to give a clearance with the more bulky early sheet metal chassis, cant remember how much but it was shown in the CCC GTM build project. John
Thu Feb 23, 2017 7:19 am |
librakv6
Joined: Sat Feb 11, 2012 2:51 pm Posts: 134 Location: NE GTM: Libra
Re: Cumbrian coupe
Lovely looking coupe you have got there and your making a good job of the restoration, keep up the good work and don't let small problems dampen your enthusiasm Jamie
_________________ V6 GTM Libra '10 years in the making!!!'
Libra V6 Hawk AC Ace TVR 3000M MG ZTT 180 Skoda Fabia VRS TVR Griffith 400 (coming soon)
Fri Feb 24, 2017 10:20 pm |
lakelandgtm
Re: Cumbrian coupe
Rear subframe along with engine and hubs are now fitted onto the chassis. Steering locking kit and handbrake kit also fitted, courtesy of Alan at Rossabitz. Front subframe hasn't been put in yet so the old wheels are counterbalancing the weight of the engine. Attachment:
Mon Feb 27, 2017 10:36 pm |
