Spyder/Libra fibreglass sample or certificate.
Just became the owner of the only Spyder in Australia.
She now has to go through an engineering certification process before road registration. One of the requirements is certification of structural fibreglass as follows.
"All fibreglass used in structural components must comply with and be tested in accordance with the requirements of British Standard 2782 Part III, methods 320E and 335A. The test panels must reach minimum acceptance levels of 85 MPa in tension and 152 MPa in flexure. The Barcol hardness value must be greater than 25 and the fibre to weight ratio must be at least 0.29.
Fibreglass panels presented for testing should be laid up under supervision in order to verify the consistency of lay up when referenced to the vehicle components being constructed. These test panels should measure approximately 600mm x 600mm and be free of gel coat. Flat (planar) test panels are required to comply with test procedures."There are four ways I can see to get this done:
1. Cut a test sample from the floor of the car (shock horror).
2. Cut a sample from a damaged panel or tub from a Libra or Spyder. Would need photos to verify the source of the sample. Size is 600 x 600 or smaller pieces adding to same total area.
3. A certificate of compliance from a person familiar with GTM build standards of the time (2005)
4. A sample prepared to the original standard and certified as such.
5. Results from testing previously performed - anyone aware of any testing of Libra/Spyder fibreglass?Any suggestions would be most welcome. Of course I am happy to pay for a suitable sample, freight etc etc.
