It is currently Sat Oct 20, 2018 12:25 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Front Clam Bushes
Post Re: Front Clam Bushes
As stated previously those big rusty bolts were (from the bits box) just to hold the parts together for welding.
Fitted the new hinges and replaced the bonnet, opens smooth as silk now. Will post pics at some point.
Tue Nov 14, 2017 6:40 pm
Stuck pics in "GTM Kit Cars" on Facebook to save on forum pic limits.
https://www.facebook.com/media/set/?set ... 028&type=3
Wed Nov 15, 2017 1:14 pm
I've just had the bonnet off again to start fitting a new rad and found one of the Oilite bushes has broken just below the flange. I'm now of the opinion that these are not robust enough (and too brittle) certainly in the size (13mm OD) I bought. Maybe the ones with 16mm OD would be better as this gives thicker wall size. EG. https://simplybearings.co.uk/shop/p1207 ... backstep=1
Or maybe Nylon or Oilon bushes would be better suited.
Thu Nov 16, 2017 6:54 pm
The low cost ones from e-bay have arrived and look good
When you consider the originals were 18+ years old I will be sticking to Nylon
Pete
Fri Nov 17, 2017 5:11 pm
What size did you get Pete? I don't see any in that listing that match the original 10mm ID x13mm OD.
Fri Nov 17, 2017 6:24 pm
I've now made some new bushes out of black Acetal, but made them 16mm OD instead of 13mm (drilled out the holes in the bonnet).
Mon Nov 20, 2017 7:37 pm
I got 10mm inside and 16mm external
Easy to drill out the glass to suit
In fact the original bushes had been running around and opened the holes to more than the 16mm
Pete
Wed Nov 22, 2017 6:34 pm
Finished hinge set.
Wed Nov 22, 2017 10:04 pm
