It is currently Mon Jan 20, 2020 5:14 am
Post new topic Reply to topic  [ 300 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20  Next
Paul's k3
Post Re: Paul's k3
Hey Catsam,
You've recently removed a subframe from a K3, aside from pipes and wires, how long did it take?
Tue Jan 01, 2019 6:13 pm
Post Re: Paul's k3
I cant reallly say how long it took me to remove the subfram as i did it in my spare time over about 2 weeks
paul
Member No 1320
Tue Jan 01, 2019 7:32 pm
Post Re: Paul's k3
tonygerrard(1049) wrote:
Hey Catsam,
Tony
When I did my K3, the removal of the Subframe on the front took about an hour once I had spent 2 days freeing off seized nuts & bolts, whilst the rear took me about 3 hours, again after freeing and cutting off even more seized fixings.
I suppose times reflect the condition of the subframes and what you need to remove to make them light enough to manhandle
J
Tue Jan 01, 2019 8:26 pm
Post Re: Paul's k3
Thank you Jaybee,
I might have to do the necessary removal of the two subframes prior to shipment and storage.
Tue Jan 01, 2019 10:23 pm
Post Re: Paul's k3
The black wheel arch has fell off with help from me
And now the blue one has fell off too
paul
Member No 1320
Sat Feb 23, 2019 6:43 pm
Post Re: Paul's k3
I have done it i cut the wheel arch off
Image Image
paul
Member No 1320
Sat Feb 23, 2019 6:48 pm
Post Re: Paul's k3
Image Image Image Image Image Image Image
paul
Member No 1320
Sat Feb 23, 2019 7:21 pm
Post Re: Paul's k3
brave stuff! Looking forward to seeing it finished!
Sat Feb 23, 2019 10:04 pm
Post Re: Paul's k3
Catsam.
Well done job! Are you going to top coat with gelcoat and cover the gelcoat with some flashtape so it gives a smooth finish. When it's gone off sand with 240 work down to 1500 then paint to match?
Sun Feb 24, 2019 8:50 pm
Post Re: Paul's k3
Hi tony i was going to use 2k acrylic hi-build primer wet sand and paint with 2k paint i think the hole car needs
a Respray it has small bubbles here and there
Image Image
paul
Member No 1320
Sun Feb 24, 2019 9:49 pm
Post Re: Paul's k3
I was not happy with the other side of the car so i cut a bit more out of the wheel arch :?
paul
Member No 1320
Thu Mar 07, 2019 1:52 pm
Post Re: Paul's k3
It's starting to look like this might work :D :D
Image Image
paul
Member No 1320
Fri Mar 08, 2019 10:24 pm
Post Re: Paul's k3
I was not happy with just cutting the wheel arches of i have started to make a centre console for my car
I started with the white sheet the pain was to make a paton then cover with fibreglass
I'm thinking of painting it with textured paint
paul
Member No 1320
Mon Mar 25, 2019 12:23 am
Post Re: Paul's k3
catsam wrote:
I have started to make a centre console for my car
You’re just showing off now :lol: 8)
J.
Mon Mar 25, 2019 5:29 pm
Post Re: Paul's k3
I don't know what to do with it gloss paint or i could paint with textured paint or cover it with something I think might paint and if I don't like it I could cover with something and make I look good
paul
Member No 1320
Tue Mar 26, 2019 5:46 pm
