It is currently Tue Apr 16, 2024 7:04 am
Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13  Next
Z Cars rear suspension
Post Re: Z Cars rear suspension
Haha don't know about that. I'm fairly confident that I'll keep improving but it is a very competitive formula. Some of the cars are certainly a bit more equal than others, too :lol:
Yeah will have been Silverstone.
Looking froward to seeing your car back on the road and hearing your thoughts
Thu Sep 27, 2018 9:52 pm
Jaykart1227 wrote:
Enjoyed the footage on board with you at Silverstone (I think?).
can you post a link?
Fri Sep 28, 2018 8:26 am
https://youtu.be/JU6chISQm48
I wake up and realise I'm in a race after a few laps :lol:
Done a lot of work to the car since then. The tyres were going off massively the more the race went on/the more confident I got to push harder. Hence the spin of epic fail at the end :(
These montages are done by a fellow competitor/committee member but there will also be a full length race on the 750MC YouTube soon filmed for Motorsport TV (previously motors TV)
Fri Sep 28, 2018 1:01 pm
Really enjoyed that. A clever bit of editing. The dice between the yellow and white cars looked very close!
Someone forgot to set the date on their camera :roll:
Shame about that spin - going well and making up some places before then!
Fri Sep 28, 2018 7:55 pm
So I finally got around to measuring the rear camber compliance on the Spyder. I used a load cell and digital readout to measure the force and a small magnetic digital level attached to the brake disc to measure camber gain (loss of negative camber). A ratchet strap supplied the force which was applied to the bottom of the tyre and reacted at the bottom of the tyre on the opposite wheel. So each wheel felt like it was the outside wheel in a cornering situation. One tyre was on a "roller skate" to allow free lateral movement and the other was on a block of equal thickness. The suspension is brand new Mk II so there is no free play in any joints or wheel bearings.
I repeated the experiment on the front suspension for reference.
The results are shown in the chart which combines data points for left and right wheels. I charted them separately but there was little difference side to side so I haven't posted that. The best-fit lines are excel trendlines and I extrapolated them to the sort of cornering force you might see on a rear tyre at 1G cornering with most of the weight transferred to the outside tyre.
In summary, the rear suspension loses about 0.5 degree of camber for each 100kg of cornering force which could add up to 2.5 degrees in extreme cornering. The front has less than one third the camber compliance of the rear, made worse by the fact that the front only sees about 80% of the cornering forces of the rear. As a rough example, consider 500kg cornering force at the outside rear with 400kg at the outside front. The camber loss would be 2.5 degree at the outside rear and 0.6 degrees at the outside front. This is a recipe for oversteer at the limit.
The easy fix is lots of static negative camber at the rear but this will wear the tyres unevenly. This would probably be acceptable for a track day setup. The real fix is a new suspension and the Z Cars design would definitely be a lot better - probably a complete fix. In defense of the factory suspension it does gain negative camber in roll due to its geometry - the Z-Cars does not. I think this gain is only enough to partially offset the camber loss due to the body roll itself ie for 3 degrees of body roll, the GTM suspension might only lose 1 - 1.5 degrees of negative camber (plus the compliance loss) where the Z-Cars suspension will lose the full 3 degrees (with a lot less compliance loss).
My plan is to one day build a Z-Cars type suspension but make it a semi-trailing arm version with the pivot axis laid back at about 10 degrees in plan view (BMW's run 12 - 15 degrees). This will give some negative camber in roll without too much toe change.
Finally - I hope someone wants to repeat my experiment on their Z-Cars rear end. It would be very interesting to know how good it is. The ideal would be for the rear camber compliance to be no more that 80% of the front ie about 0.0012 degrees/kg (or less).
Sat Sep 29, 2018 9:16 am
Hi Spider - really interesting experiment. I'll keep that in my book of excuses for my spins on track :D
Mine is mark 1.5 rear suspension (land rover track rod ends rather than pillow joints). From comparison with a friend's mark 2 I believe mine has a bit less compliance but there is no doubt it loses negative camber considerably on track cornering. My evidence is much less scientific though - basically I have some photos that people have taken of me on track from an angle that gives a reasonable perspective of the rear wheel camber. In photos of the car cornering hard the outside rear looks like it has gone into slight positive camber (relative to the plane of the car to discount the roll angle). when I first got the car the rear was set with only about 0.5 degrees of static negative camber and on track photos it looked like about 1 degree of positive and I was finding it very easy to spin! I dialled in 1.5 degrees of static negative and photos now show it only very slightly positive and it is much more driveable but does still snap oversteer when you cross the limit. I don't want to add any more static camber as I find on the road it gets a bit "tramliny" with more and I don't want to be adjusting it back and forth all the time. Recently adding ARB's has made things better again and I just need to grow bigger balls to find the limits now!!
The other impact of the compliance is that toe-in reduces under load. Did you measure that? When set parallel it goes to toe out and that also contributes to the tendency to spin!! I've found a relatively small toe in sorts that out though.
Sat Sep 29, 2018 11:30 am
It's worth noting that at least some of the movement will be in the rear bulkhead. Through production the thickness of the bulkhead varied quite a lot. I believe the Spyder had a thicker rear bulkhead than the Libra due to the lack of roof.
The Z Cars suspension of course removes this flex with the large beam across the bulkhead.
Some owners have linked the standard suspension brackets with a steel box section across the bulkhead to help remove some of the flex. I forget what the movement was in all the joints when analysis was done in the TGTM days but from memory about half the overall was the bulkhead.
Sat Sep 29, 2018 11:55 am
Hi Sanzomat.
I didn't measure toe change under lateral load but I would be surprised if it is that bad. The factory geometry adds toe-in in bump which would help. The Z-Cars rear would toe out slightly under lateral load.
Sat Sep 29, 2018 12:31 pm
Is that your Spire for sale on fleabay Ryan? what are your plans for next season?
Sat Dec 08, 2018 8:38 pm
It is mine yep, planning an upgrade
Mon Dec 10, 2018 12:17 pm
does anyone know the correct way to fit the handed lower balljoints as used on the later style rear arms if you fit left hand one as would be on a mgf to left side of the car it moves the balljoint centre forward slightly this shortens the lower arm and gives more toe in under compression of suspension as the outer wheel would be in hard cornering and may help to cancel out the toe out caused by the flex in the bulkhead.The instructions in manual say the handed balljoint should not not be used will 17 inch wheels which makes me think maybe this is because the handed balljoints should be fitted on opposite sides moving the balljoint back so will 17 inch wheels they will touch rear clamp pivots on engine frame manual does not say why they cannot be used with 17 inch wheels in ideal world there would be no flex in bulkhead or bump steer
Sun Jan 06, 2019 11:53 pm
maybe there will be some to look at at stoneleigh to compare as no one has replied
Mon Apr 22, 2019 10:27 pm
Hello chap, I don't know the answer to your question but you could loosely put it together without the coilover on & check if you have clearance within the expected range of movement? I could imagine that 17" wide wheels would be tight clearance wise.
I've not looked at the arms in that much detail to be honest but with the length of the arms the relative difference by swapping ball joints would appear to be fairly small? I guess every little helps though!
Stew
___________________________
StewB
'09 Libra K20
'69 TVR Vixen V8
'86 Capri 2.8i S
‘78 TVR 6200M-TT
Ex Libra V6
Tue Apr 30, 2019 8:39 am
Thankyou for your reply i am more interested in effect on suspension geometry than clearance i think shortening the distance between lower arm pivots will give more toe in when suspension goes up this may compensate for the bulkhead flex giving toe out due to lateral cornering load .I have looked at two cars today at stoneleigh both have righthand lower balljoint on left side this will lengthen arm which is probably why instructions say handed balljoints cannot be used with 17 inch diameter wheels due to clearance problems with clam pivots
Mon May 06, 2019 10:25 pm
Can anyone tell me the size of the rod ends used on the Z Cars setup? Look like 16mm from the photos but can't be sure.
Tue Jul 02, 2019 2:43 am
