Jaykart1227
Re: Z Cars rear suspension
I know they are an imperial size and the bolt hole is 1/2". I can measure the threaded part for you at the weekend if required.
Tue Jul 02, 2019 8:01 pm |
Spider
Thanks Jaykart. They might be 1/2" x 5/8".
Thu Jul 04, 2019 4:14 am |
PhilTheGeek
I've had a look at my spares this evening and they're definitely 1/2" bore and 5/8"UNF.
Sat Jul 06, 2019 10:02 pm |
Spider
Thanks Phil and Jaykart.
I am designing a rear suspension for my Spider based on the Z Cars system. It will be semi trailing for some camber gain and higher roll centre.
Sun Jul 07, 2019 10:56 pm |
Spider wrote: Thanks Phil and Jaykart.
I am designing a rear suspension for my Spider based on the Z Cars system. It will be semi trailing for some camber gain and higher roll centre. If you feel like making more than one I might be interested (obviously cost dependant). Z cars style with camber gain and higher roll centre seems like the holy grail!
Mon Jul 08, 2019 7:17 am |
Spider
sanzomat wrote: Spider wrote: Thanks Phil and Jaykart.
I am designing a rear suspension for my Spider based on the Z Cars system. It will be semi trailing for some camber gain and higher roll centre. If you feel like making more than one I might be interested (obviously cost dependant). Z cars style with camber gain and higher roll centre seems like the holy grail! It probably wouldn't be cost effective to build and ship from Australia and there will be some aspects (eg engine mount for my Toyota engine and steady bars for Rover engines) that won't transfer. However I am designing in Solidworks and will happily share the plans when finished.
Mon Jul 08, 2019 11:06 pm |
I'd love to see the plans when you've done them. Solidworks imports into .dwg doesn't it? I don't think my fabrication skills are up to the task but I know man who can!
Hope the design goes well.
Tue Jul 09, 2019 7:26 am |
Spider
Yeah Sanzomat, I can easy convert all the drawings to pdf or dwg, sheet metal profiles to dxf (for laser or water-jet cutting). This is what it looks like so far. In plan view the pivot axis is 10 degrees to the axle line. In front view it is 2 degrees, rising towards car centreline. (That's with 2 deg negative camber. Axis inclination is 3 deg with 1 deg camber, 4 deg with 0 camber etc). It uses the Ford eccentric bolt adjusters (from late Libra/Spyder rear suspension) for camber adjustment and extending the rod-ends for toe (same as Z Cars). Rover 100 and MGF are not common cars in Australia so the only way I can get parts to measure is to dismantle my car (which I will do when I get a bit closer). In the meantime, if anyone has a CV and/or a drive flange sitting around, could they check the measurements (Numbered 1-12 and A-I) on the drawings below? Some of them I know to be accurate and some are just a guess. I don't need super accurate numbers - within 0.5mm would help.
Thu Jul 11, 2019 1:23 am |
Jaykart1227
This looks great and having a slightly higher toll centre will be a good thing certainly. One thing I’d suggest is to make the outer rose joint length adjustable via a sleeve or some such (similar to the original MK1 adjustment on one of the track rod ends)......adjusting the toe via removing the arm and winding in and out nearly drove me insane
Sun Jul 14, 2019 11:43 am |
Spider
Thanks for that suggestion Jaykart. I will go back to an earlier plan where one of the eccentric bolts adjusts camber and the other adjusts toe. I am a bit nervous about that because it only allows plus or minus 1.25 degrees of camber adjustment. That's plenty provided the welded assembly is accurate within say plus or minus 0.5 degree.
Mon Jul 15, 2019 3:34 am |
Jaykart1227 wrote: adjusting the toe via removing the arm and winding in and out nearly drove me insane If the bracket on the tub has a space wider than the largest dimension of the rose joint eye end wouldn't it be possible to adjust it by removing the bolt and spacers and rotating the rose joint then putting back the spacers and bolt? No need to rotate the whole arm? or am I missing something?
Tue Jul 16, 2019 8:58 am |
Jaykart1227
sanzomat wrote: Jaykart1227 wrote: adjusting the toe via removing the arm and winding in and out nearly drove me insane If the bracket on the tub has a space wider than the largest dimension of the rose joint eye end wouldn't it be possible to adjust it by removing the bolt and spacers and rotating the rose joint then putting back the spacers and bolt? No need to rotate the whole arm? or am I missing something? In theory that should be possible if the joints sat dead centre in the brackets.....unfortunately, in reality, the joints are very close to the side of the brackets in order to get the correct track width so you can’t. I had to take both bolts out every time, pull the arm out, make a turn on the joint, bolt the arm back in, drop the car down, roll it back and forth to settle the suspension, set up my tracking brackets and string lines (and you can’t measure from the spindle ends as this moves every time you adjust the toe on the arm, you have to set your string from the inner joint position), make a measurement.......and then invariably find that you’ve got to go a bit more so rinse and repeat It really is a massive pain in the arse! Once set it shouldn’t move though. If I was making a version of this again I would insist on the outer joint being sleeve adjustable to avoid all the faffing about and to ensure that you could get the toe absolutely spot on easily. It’s something I may have Dave at TD look into modifying in the future but for now I’m happy it’s set right. I would definitely think twice about playing with toe settings though so making it easier to adjust would be high on the agenda for me if doing it again.
Tue Jul 16, 2019 10:52 pm |
Spider
Spider wrote: In summary, the rear suspension loses about 0.5 degree of camber for each 100kg of cornering force which could add up to 2.5 degrees in extreme cornering. The front has less than one third the camber compliance of the rear, made worse by the fact that the front only sees about 80% of the cornering forces of the rear. As a rough example, consider 500kg cornering force at the outside rear with 400kg at the outside front. The camber loss would be 2.5 degree at the outside rear and 0.6 degrees at the outside front. This is a recipe for oversteer at the limit. The easy fix is lots of static negative camber at the rear but this will wear the tyres unevenly. This would probably be acceptable for a track day setup. The real fix is a new suspension and the Z Cars design would definitely be a lot better - probably a complete fix. In defense of the factory suspension it does gain negative camber in roll due to its geometry - the Z-Cars does not. I think this gain is only enough to partially offset the camber loss due to the body roll itself ie for 3 degrees of body roll, the GTM suspension might only lose 1 - 1.5 degrees of negative camber (plus the compliance loss) where the Z-Cars suspension will lose the full 3 degrees (with a lot less compliance loss). Finally - I hope someone wants to repeat my experiment on their Z-Cars rear end. It would be very interesting to know how good it is. The ideal would be for the rear camber compliance to be no more that 80% of the front ie about 0.0012 degrees/kg (or less). I have done some FEA on a simplified model of the alternative design trailing arm (similar to Z-cars) with 3mm wall thickness steel. The camber compliance (arm only) is 0.0003 deg/kg This is 17 times stiffer than the factory setup! There will of course be some flex in the wheel bearings, rod-ends, brackets etc but there will still be a massive improvement in overall compliance/stiffness.
Thu Oct 12, 2023 1:09 am |
