It is currently Tue Apr 16, 2024 11:58 pm
Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
New Member F41 GTM Automatic to Manual Conversion
Post Re: New Member F41 GTM Automatic to Manual Conversion
I knocked out the actuator shaft because it was very stiff.
After a clean with some wire wool and some fresh grease it moves very easily but has no play which is good news!
Wed Feb 12, 2020 9:02 pm
You can get replacement clutch arms that have a grease channel and nipple so they can be greased without having to take GB off.
I have one on the shelf unused thus far though, as you have to take GB off to fit the arm.
Wed Feb 12, 2020 9:36 pm
Good to know!
Wed Feb 12, 2020 10:38 pm
Did you use a sealant on the mating faces?
Fri Feb 14, 2020 5:39 pm
On the mating faces of what?
Fri Feb 14, 2020 10:00 pm
Gearbox casing to engine block.
Fri Feb 14, 2020 10:32 pm
Nope, why would you do that?
Fri Feb 14, 2020 11:06 pm
So a small update!
Because my car was Automatic it had a center console, this made using the MGF gearchange unit somewhat easier.
It means l have a bit more space to play with.
I cut the weight off because that would hit the sides of the tunnel, springs now give some self centering.
The hole in the tunnel is rather large but it was already there.
Sun Mar 08, 2020 9:06 am
Springs added
Sun Mar 08, 2020 9:08 am
Center console.
Sun Mar 08, 2020 9:09 am
Interesting on the buggy I never found the self centring an issue the cakes kept the stick in the right place. But I like the idea.
Cakes lol, autocorrect on the phone, I obviously meant cables
Sun Mar 08, 2020 11:03 am
I haven't got the short cable attached yet, I have the wrong combination of parts and it's about 70mm too short.
Have ordered an MG TF bell crank and an MGF short cable.
At the moment I have the opposite combination :roll:
I also ordered an MG TF cable holding bracket UKU000020.
Sun Mar 08, 2020 3:30 pm
I can highly recommend https://www.mikesatur.co.uk/Bell-crank-MGF if you're having to replace the bellcrank
Sun Mar 08, 2020 4:48 pm
Well although I am not yet tearing around in my manual GTM the car is running and quite happy, so the ECU doesn't care which gearbox is attached and the 1.8 MGF flywheel I used is compatible with the car, happy days.
Just some finishing off to do with the gearchange and tidy the seats and I am good to go!
Tue Mar 17, 2020 9:24 pm
My Libra is done!
Fri Apr 10, 2020 11:59 am
