Rear clam supports - Spyder
I've discovered that the rear clam supports on my Spyder are not parallel to the clam when it's in the down position. They touch at the back but not at the front (see drawing a). There's not enough adjustment to allow them to be corrected as the bolt-on right angle supports are in their lowest position and can't be dropped further due to the fact that the plates on the engine frame won't allow any more movement.
I'm sure that if they fitted correctly and had some rubber to cushion the weight slightly it would reduce some of the rattles. The clam currently needs a good pull/shove to get the screw holes aligned with the spire nuts and this may also be improved with better fitting supports.
Before I take an angle grinder to trim the chassis of a very rare car (drawing b)
is this a problem anyone else has encountered and has anyone got any thoughts or comments?
Thanks.
