It is currently Thu Apr 18, 2024 5:25 am
catylitic converter?
Post catylitic converter?
quick question, does a new build need a catalytic converter if the engine used is post 1992?
Thu Oct 22, 2020 9:41 am
Post Re: catylitic converter?
I think you will find it does it goes on engine age
Ian
Thu Oct 22, 2020 12:43 pm
There is a grey area between 1992 and 1994 when engines already in production could continue without catalysts so I believe kit cars can treat the cat cut off as 1994.
I was under the impression that if you use a mixture of old and new parts and the used parts are from different donors so you get a Q reg then the emissions are a basic smoke test but not absolutely sure if that applies to ones being tested now.
Thu Oct 22, 2020 1:47 pm
Sanz may well be correct if its a Q plate but think you will still need the cat
Ian
Thu Oct 22, 2020 7:49 pm
My car was OTR in 2000 with J-reg age plate a 1.4 from said J-reg donor. No cat on donor so none was req'd
When I changed to a 1.8vvc (brand new) a couple or so years later i didn't fit a cat nor was told to by anyone in officialdom. So it has been ever since and all MOTs have used BET no cat test specs.
I read cats were only mandatory 1995ish onwards. There was a few years before that of transition where some had some didn't
Page 46 of the IVA manual has a flow chart https://assets.publishing.service.gov.u ... hicles.pdf
It depends on whether an exact match can be found for the car under test I believe here https://assets.publishing.service.gov.u ... dition.pdf
As GTM Libra is not listed you'll end up with a non cat BET CO<3.5% and HC<1200ppm
All of this will also have a bearing on what road tax band or category you end up in I think.
Sat Oct 24, 2020 9:24 pm
Hi - someone in charge
I cannot write a reply from the Libra pages - so I tried this one and it works
Trying to do a reply on 'window rubbers'
Pete
Thu Nov 26, 2020 4:31 pm
Happened before, see;
picture-bug-and-replying-to-posts-t4387.html
Thu Nov 26, 2020 5:10 pm
