Found on the GTMOC Yahoo Group: -
Re: Libra Quick steering
It is possible to use a MG TF rack (2.8 turns lock to lock). GTM can supply
the shorter steering arms.
Guido
http://www.gtmv6.com--- In
gtmoc@yahoogroups.com, "gordon_tyreman" <geologistrig319@a...> wrote:
> I haven't seen any info about steering mods on the Libra so here are
> some thoughts. When I first drove my Libra I realised that the
> steering was very light and also very low geared for a sports car at
> 3.7 turns lock to lock. I decided that this did not give sufficient
> feel and also precluded the possibility of getting sufficient
> opposite lock on if the back end ever decided to drift. The
> modification I have made has I believe significantly addressed and
> improved these two conditions.
> The steering rack on both the metro and Metro gti are the same but
> stops are added to the gti to prevent fouling by the wider wheels so
> either rack can be modified to the same effect.
> The GTM steering arms are effectively 140mm long from notional king
> pin centre to centre of the track rod end. This can be shortened by
> whatever you feel will give you the characteristics you desire. I
> modified mine by shortening to 100mm ie remove 40mm from the steering
> arm and machine a new morse tapered hole (cost 25 quid at the local
> engineering shop) This gives you a comparable lock to lock of 2.6
> turns, though in effect this is more because the new lock with
> shortened arms is considerably tighter. The new lock gives no
> problems of fouling on the body work, in fact the first place the
> wheel touches is the wishbone. A few words of warning here, the MOT
> requires the wheels do not foul on the body or suspension so jubillee
> clips can be added to limit the extremities of lock. Also the
> steering arms supplied by GTM are angled inwards at the front in a
> plan view and also ramp up and then level out in the side view. These
> angles are intimately related to the steering geometry and cannot be
> ignored.
> For this reason the maximum reasonable reduction would be to the
> point at which the arm starts to ramp up ie 40mm from the original
> track rod end location. Also because the act of relocating the track
> rod end rearwards also moves that point outwards the new mounting
> point must be drilled 3.5mm inboard of centre to restore the
> geometry. If this is not done accurately then hideous bump steer will
> result. In fact I did not allow for this and had to heat and bend the
> steering arms to restore perfect geometry. The result is that
> steering is now a bit heavier at parking speeds but not oppressively
> so and feel and response are much improved. I know one or two other
> people have made similar mods; subsequently Bryn reduced his by 20mm
> and that was a good compromise I believe. Of course the new offset
> for the tapered hole would in that case be about 1.8mm to eliminate
> introduced bump steer.Because reducing the steering arm length
> effecively reduces the Akkerman steering geometry you should
> compensate by reducing toe-in. In fact I run 2mm toe out and the
> steering feels great and tram-lining is reduced, with no tyre wear
> problems. If you feel the steering needs more feel and responsiveness
> don't hesitate to do this modification I am extremely happy with the
> results I have achieved . Gordon
