It is currently Thu Sep 09, 2010 3:51 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
Libra hazard switch
Post Re: Libra hazard switch
As you've got a "plastic" car, I would say you need to check that all the ground wires (black) are connected to the negative of the battery. There may be a broken wire or crimp somewhere, which would cause a problem like you are describing.
Poor earth connections are notorious for developing faults in other circuits of the car, as they back feed.
Get a bulb holder, connect one side to the + of the battery and then touch all of the black wires, one at a time. If it doesn't light up, then this is where the fault is.
Thu Dec 17, 2009 1:23 pm
I have;
Green - Live Permanent 12V
Red/Black tracer - Ignition no reading, lights on I get 350 Ohms
Black - Ignition/Lights - 2 Ohms (put live to this and dash lights come on)
Blue/Purple - Ignition live 12V
Green/White - Ignition - no reading, with lights on 11/12V
Green/Red - Ignition - no reading, with lights on 11/12V
Light Green/Orange - 5V with lights on
Light Green/Purple - 5V with lights on
With regards to the switch the above lotus diagram is the correct one but the colours are different to mine.
Really appreciate this I'm having a right struggle!
Ryan
Thu Dec 17, 2009 2:28 pm
I understand what you mean and I agree but I still need to know how to wire the switch, because in trying to find a fault, thinking the switch was broke I ended up pulling all the wires off the switch in haste without noting down what went where.
I think I've figured out that the Blue/Purple had lost it's live as I got nothing from that wire and that should be the Switch ignition live. It backs that idea up too because the indicators worked, but when pressing the switch it uses the switched live instead of the permanent and nothing worked. So if I'm right with the Blue/purple wire I just need to put the switch back on now.
It's a little beyond me, if you could try to figure out what wires go where on the switch for me from the above post and switch diagram it'd be a massive help!
Thu Dec 17, 2009 2:33 pm
Right!
Get a jumper wire - (just a bit of wire) and jump Green to Green/White and Green/Red in turn. This should illuminate the indicators on each side in turn. If not, you have dodgy earths at the indicators themselves.
Then, wiring wise
Green to no.3
Blue/Purple to 2
Green/White to 4
Green/Red to 6
Black is incorrect. Run a new black cable from 7 to a good earth
Red/Black to 8
The other two to 1 and 5, if it doesn't work, swap these 2 around.
If it still doesn't work, find the hazard flasher unit, and check the black wire from this to earth.
If nothing, replace hazard flasher unit.
And that's as much as I can do from a distance.
It's got to be frunky.
Thu Dec 17, 2009 2:55 pm
IT WORKS!!!!! :D
Thankyou!!
Thu Dec 17, 2009 4:44 pm
Spoke too soon, one thing now...
Hazards work - Great!
If I put the headlights on the backlight doesn't come up for the clocks but my dials move? Then turn lights off and the dials go back down.
Thu Dec 17, 2009 5:09 pm
Unplug the Red/black wire, all it does is illuminate the switch (hopefully, can't tell from the diagram)
Thu Dec 17, 2009 5:36 pm
Switch still lights up and problem still occurs... maybe its mixed up with another?
Thu Dec 17, 2009 5:45 pm
Are you on your old or new switch?
This can be a few different things:
In most likely order:
1 Swap the wires on 1 & 5
2 Dodgy earth on hazard flasher unit.
3 Dodgy earth on your clocks.
4 Dodgy earth on either front or more likely rear lights
5 Blown resistor inside the switch
6 Wrong hazard flasher
Thu Dec 17, 2009 6:02 pm
I've had a good chin scratch.
As that red/black wire has no effect we must have a current leak from the hazard circuit into the sidelight circuit or vice versa - and the most likely cause of this is the earths for your indicators/lights themselves. Or possibly still a bad earth to your clocks or indicator stalk.
Whichever, it's tome to methodically check your earths - start with the rear light clusters.
Thu Dec 17, 2009 6:17 pm
