MickC
 Registering my K3
Hi can anybody advise me on the way I go about registering a K3 that I have just baught as an unfinished project any information I will be most greatfull thanks Mick
| Sun Dec 13, 2009 5:19 pm |
Pantera2075
Joined: Fri Oct 12, 2007 9:38 am Posts: 698 Location: Stoke
 Re: Registering my K3
If it has never been registered you will probably need to put it through IVA.
Nasty.
Do all in your power to find if it has ever owned a number plate. Otherwise, get ready for governmental red tape.
_________________ It's got to be frunky.
| Sun Dec 13, 2009 5:52 pm |
lyndiloo
As stated if not already registered then it will need an IVA test. Earlier this year I managed to get a different kit car through the SVA test but it was totally different to a K3 and I had to do a llot of messing around. I also have a K3 which is correctly registered so don't need to go through that again. Having said that and having looked at the K3 I don't think it would be too difficult to get through as a lot of the items are based on sharp edges (internal and external) Vision (mirrors, folding in if hitting a pedestrian and the view to the rear) Braking and suspension (well it is basically standard Metro so shouldn't be too much to worry about) Lighting should be ok. The areas that might be an issue are the seat belts (hieght from base of seat and what they are fixed to and possibly the fuel tank (I believe that it should be outside the cabin and not in the engine bay (could be wrong on this point it was just something someone else had said). If you haven't got an original bill of sale for the body you may come up against an issue when you want a registration and unless it has changed in the last year you will get a Q plate if you don't have it, if you do have it then you should get an age related plate to whatever the donor vehicle was (you will need to prove that most all the parts came from one donor car to get that). A couple of other points: Take a load of photo's in various stages of the build otherwise you will go through hell trying to prove that you built it and that it wasn't done by a company (different rules and regulations to go through on the test) This is not written down anywhere but trust me on this, as it is a pain trying to prove otherwise. Don't tell them someone else started it and you finished it, say that you bought it as a none started project. The test fee is bloody expensive now (not far off £500 I believe) and few cars pass first time, the re-test is about £90. I would go on to something like the locost forum to see what they are doing and having to say about the new test as they are still building cars to get through it whereas most GTM's have either been through it already or didn't need to because of the age of them. Good Luck.
| Mon Dec 14, 2009 9:34 am |
Malcolm_Ball
Joined: Sun Sep 30, 2007 4:37 pm Posts: 298 Location: RM13 ish
I think at least 1 of the last of the K3's passed an SVA test - but I'm not sure enough to put money on it.
_________________ Malcolm GTM(s) & VAG PD130 oil burner.
| Mon Dec 14, 2009 3:12 pm |
RaymondH
If you need to IVA You're going to have fun, I'm afraid. I'm (re)building a Mk1 Rossa and the regs are a real pain. You can download them here http://www.businesslink.gov.uk/Transpor ... sion_4.pdf and it would be worth your while ploughing through them. For the actual registration process Google VOSA and you'll find it that way. The main problems I'm having are glass (windscreen and doors must be E marked - no kite marks allowed now) fuel tank (location is ok but filler must be outside car: I think your problems might be vice versa to mine) steering wheel(collapsible column required and no holes etc in spokes which must also be padded) brakes (must be dual circuit) chassis number (must be at least 17 letters/numbers at least 3.5mm high and stamped on car) sharp edges (must have 2.5mm minimum radius and 19mm radius underneath dash) lighting (bonnet opens up with headlights so combined indicators/sidelights needed) wheels and tyres (no rubber must be visible at all when looking directly down on arch and also for a certain radius around wheel) instruments (also sharp edges  so have had to change bezels) etc etc Some of these are easily enough fixed (and might not apply to a K3) but take money - lots of it  Test fee is £450 plus £90 for a retest..... You can read some of my meanderings here my-rossa-project-t485.html I'm not trying to put you off but it's better to find out now before you get in too deep and spend tons of cash like I did. Never mind, it's still good fun
_________________ Illegitimis Non Carborundum
| Mon Dec 14, 2009 10:56 pm |
reddi-eng
Joined: Mon Aug 03, 2009 11:08 am Posts: 69 Location: Worcestershire
RaymondH wrote: ...... I'm (re)building a Mk1 Rossa and the regs are a real pain. Good luck RaymondH with your Mk1 Rossa rebuild if you are having to (re)register it under these regs. Just a quick look through and a compare with my recently acquired Mk1 shows a lot of points not up to current standards. Although some may seem a bit petty, many are common sense and I think will guide my rolling restoration.
_________________ Derek __________________ Mk1 Rossa Q881 UOE C-MAX Everyday Drive
| Tue Dec 15, 2009 11:59 am |
lyndiloo
A lot of the things RaymonH has said will not apply to the K3, for example collapsible steering already in with Metro column, anti theft again in column, front screen is e marked, side screens may not be so remove them and put a T piece of rubber in the door top to seal. (if not on the vehicle they can't fail it). Wheels and tyres not an issue, radius to dash should be fine if my one is anything to go by, brakes/reservoir etc. no issues. The one item I would need to get clarification of is the front and rear clam lights, if I understand what has been said does that mean that side lights and indicators have to be visible even when the clam is in the open position? if so this would need a bit of thought to overcome. Maybe you could make the clams unbolt as a unit so that it isn't something that could be done at the side of the road but only if you have two people and some tools (just musing here) I assume it is to ensure that lights of some sort or indeed hazard lights can be seen if you are broken down at the side of the road when you have the bonnet up. Other than the last item I don't see too much to worry about Oh except the cost. Good Luck.
| Tue Dec 15, 2009 12:42 pm |
RaymondH
Yes, the sidelightsand hazard warning lights must be visible from a certain distance all round (can't remember what off the top of my head) with all opening panels open. The sidelights in the headlight would fail because they sit back in the scoop. I bought a pair of combination lights from CBS for just a tenner. As reddi-eng says, most of it is common sense and it looks as if most of my issues don't apply to the K3 anyway but just be on your guard...
| Tue Dec 15, 2009 5:27 pm |
MickC
Hi and thanks for all the words of wisdom I baught the K3 thinking that it was going to be a staight forward prosess of registering it when I had completed it however I now see it a little differant .Firstly the build manule that I have leaves i lot to the imagination as to how anything goes and where any one who can help I would be very greatfull as for the registering I will look at that when( Ha! Ha!) I complete the kit
| Sun Dec 20, 2009 11:12 pm |
Malcolm_Ball
Where abouts are You ?
| Mon Dec 21, 2009 12:13 am |
MickC
Hi there I live in telford shropshire
| Mon Dec 21, 2009 6:55 am |
Pantera2075
A-ha, i'm not far off, you have a DVLA office local in Shrewsbury, and a contact or two there. And you're in my "patch".
| Mon Dec 28, 2009 2:05 am |
ibrooks
Joined: Mon Feb 04, 2008 5:41 pm Posts: 101 Location: Darwen, Lancashire
MickC wrote: as for the registering I will look at that when( Ha! Ha!) I complete the kit Problem is that you can then find yourself having to make fundamental changes to jobs you already thought were finished and pulling a "completed" car apart again to make it comply with the regs. It's a lot better to build with one eye on the regs as you can try to make sure it's right first time rather than having to revisit things later. Iain
| Mon Dec 28, 2009 1:44 pm |
MickC
I have started to try and sort the wiring out (without a wiring diagram ) any way when I have conected up the dash and all the engine conpartment I have the turn signals lights come on when I turn the key and if I put the lights on they also come on has anybody got a clue as to the problem. I would have thought that some where the wiring is wrong but the plugs all look ok any body with any sugestions I would be most greatfull .
| Tue Dec 29, 2009 6:31 pm |
Joined: Fri Sep 14, 2007 10:34 pm Posts: 883 Location: Somewhere between VTEC and redline
A very poor earth somewhere and its using indicators as an earth or as you say a serious wire crossed somewhere. sounds like a fun one to solve
_________________ IF wile e coyote had a GTM he would have one with Nitrous too! watch out road runner! The First GTM into the 11s, PB 11.00 @ 124.98 Mph on A048 tyres!
| Tue Dec 29, 2009 9:29 pm |
