It is currently Tue Apr 16, 2024 11:13 am
Seat Belt Mounting on Spyder
Post Seat Belt Mounting on Spyder
I am thinking of replacing the standard seat belts on my spyder with a 3 point harness. But on checking I cant see how the seat belt bracket is secured to the body on the sill side. I dont want to undo the bolt and find that the nut falls into the sill with no way to get access to it. I have checked under the sills and there is no access holes. So how did the factory manage to secure the seat belt bracket???
Thu Feb 26, 2015 5:49 pm
Post Re: Seat Belt Mounting on Spyder
Hi,
You should have several access holes inside the car? Its how all the suspension, Frame and everything else is attached? Might need to remove some carpet etc?
Juls
Fri Feb 27, 2015 1:42 pm
Thanks Juls I will have a look and see what I can find :)
Brian
Fri Feb 27, 2015 3:11 pm
