Re: Setting up the Coupe ride hieght
malc jones wrote:
PS. I would also like any info anyone can give on arranging the throttle pedal as a cross shaft accross the floor so that the cable acts directly from the side wall of the tunnel to the carb without any significant bends.
My Coupe back when i first got it had this arangement, but it did not suit me and i went away from this as a pure cable system was lighter and if you find yourself a ptfe lined cable its silky smooth. my cross bar was from the previous owner and was primative and certainly didnt feel right. when i re-engineered the car i went away from it out of preferance./simplicity.
On ride height i can only suggest to set the coupe ride height nose down, it does help high speed stability, and with one inch of rake on the chassis the floor is at 1 degree and a simple diffuser! altho the seat pans are still not 100% level with the ground tho. from memory i currently run 135mm and 165mm ride heights
