Spring rubbing on engine frame
I fitted my shiny new Protech shocks today - remarkably easy and not one seized bolt
The offside rear spring will definitely just touch the engine frame at times, is this normal? Its obviously been happening with the old Gaz shocks / springs as well.
Not too worried as the cradle will be coming out soon and I'll grind away some clearance in the offending areas but wanted to check this is the norm.
As an aside, I weighed the Protech shocks against the old Gaz units and the total weight saving is 3.1kg despite 12" rear springs on the new Protechs as apposed to 10" on the Gaz.
