thunderossa
thunderossa
At last its coming together The rear bulkhead has been modified Angle iron inner sills bolted in for strength The hoop has a diagonal and crossbrace with bracing to the sills The rear suspension is in place and works By next weekend it should be on four wheels
Mon May 25, 2009 11:01 am |
Allen7
Re: thunderossa
Interesting,
I was thinking on similar lines - similar modification to the roll bar but would use inch square tubing rather than angle and might have one length on the floor and one level with the top of the sill - with triangulation, naturally. Tie it in at the front with the dashboard support metalwork. Add a couple of bits of tubing accross the floor (like the bits the seats used to mount on). This gives the option of removing the whole floor section inside the tubing frame and replacing with a carbon fibre sheet.
Still, all i'm doing is thinking and talking about it - well done for getting on with it.
Regards,
Allen
Mon May 25, 2009 10:01 pm |
thunderossa
Re: thunderossa
Hi Thanks for your comments
My problem is I am ramming out of time. When the rear sub frame is in I will run box section from this to the angle and a cross bar to mount the seat on. This will take the longitudinal forces on a drag strip
Once I have done the meeting I will be fitting a full cage from the hoop picking up the front sub frame... then the floor can be cut out
Hope to add photos of this next week.
Mon May 25, 2009 10:55 pm |
turbocox
Re: thunderossa
Aside from the time issue, the Rossa's looking great! The usual Avon park suspects, are willing you on to get it done in time Keep pushing and I'm sure you'll get it to a level of compleatness for a few blasts up the 1/4 Neil have you started your mods yet?
Tue May 26, 2009 8:48 am |
Re: thunderossa
Looking Good lad Simular in respects to how I would approach, mount it off the hoop and brace the hoop into the car my scetch envoles a full cage. My mods stuart are going slow , Spent all weekend within "The Engine" got a shopping list of new bits and hoping to place an order to the states this week. havnt touched my frame for over a month West
Tue May 26, 2009 10:46 am |
thunderossa
Re: thunderossa
Hi 4 wheels at last !!! I still have a problem with the tie bars that stop it steering as they foul on the shockers. I had built it with the calipers to the rear but then the shocks fouled the brake pipes. The car is being brought to my house this week and so i will be able to work on it everyday Ill keep you updated (how many days to go)
Mon Jun 01, 2009 7:53 pm |
turbocox
Re: thunderossa
Mon Jun 01, 2009 8:47 pm |
PKR
Re: thunderossa
You could try using metro steering arms on the rear hubs? These are longer and might bring the steering tie-in bar out from the coil-overs.
Mon Jun 01, 2009 9:47 pm |
the other Tim
Joined: Sat Sep 29, 2007 12:23 pm Posts: 487 Location: suffolk GTM: Cox/Coupe
Re: thunderossa
_________________ I'm not a complete idiot, parts of me are missing!!!!!
Mon Jun 01, 2009 11:00 pm |
thunderossa
Re: thunderossa
Thanks for your suggestions
Ill try the metro first as i have one
If not a new arm will have to be made as it has to pass between the hub and the calliper
Pics tomorrow
Mon Jun 01, 2009 11:59 pm |
turbocox
Re: thunderossa
On another note, It will be interesting to see how much it will tip the scales at ??? any idea Thunderossa ?? Anyone one want to take a Guess ?? I'll say 550 kg's
Tue Jun 02, 2009 10:07 am |
Re: thunderossa
What have you bolted the lower shock mount too?
For the steering arms I would look into making my own up that are a litte stiffer than the mini steering arms giving less toe compliance
Weight wise my bet is on 650Kg
Tue Jun 02, 2009 10:38 am |
thunderossa
Re: thunderossa
Hi My aim is for 600kg with a front subframe in and less when it is replaced. In a couple of weeks i will be able to corner weight it.
Came up with two ideas today one easy but ugly and weak The other a better idea and will give me a good idea of what the finished part will do. Both pick up one bolt hole,so i will cut and weld another arm then add a strength plate afterwards
West has the best idea but it will take time to have one made(must get a miller)
Let me know what you think
Tue Jun 02, 2009 7:13 pm |
thunderossa
Re: thunderossa
Sorry West didnt read the first bit
I have welded a tube to the bottom arm ,webbed it underneath Useing adjustable bottom arm and uprated tiebar any twist is taken out
It appears strong enough and does not twist but i cannot do a shock test.
Im hoping a day on the rolling road will test most things
Tue Jun 02, 2009 7:29 pm |
turbocox
Re: thunderossa
Update please I'd love to know how its coming along
Fri Oct 23, 2009 10:13 am |
