It is currently Sat Nov 21, 2026 11:18 pm
Coupe wheel base
Post Coupe wheel base
Afternoon I'm wondering if someone could help , I'm carrying out a project on a coupe and am after a couple measurements firstly wheel base, centre of front wheel to centre of rear and also centre of front wheel to edge of frount sill and the same with the rear wheel any help would be much appreciated thanks Simon
Sat Mar 24, 2018 4:20 pm
Post Re: Coupe wheel base
Hi Simon & welcome
The wheelbase (as described on the spec sheet supplied by GTM in the 80’s) is 84”.
You may find more of the info you require in this link:
http://www.lightauto.com/gtm.html
Sat Mar 24, 2018 9:43 pm
I emailed Simon earlier with some measurements from my car
Sun Mar 25, 2018 10:18 pm
I also emailed Simon, but will stick them on here as a comparison for others.
This was the Right hand side of the car, really should of measured both sides and took the average ;)
Front wheel centre to sill = 360mm
Front wheel to rear wheel centres = 2142mm (sales material says 2133.6 so 8mm out)
Rear wheel to sill = 330mm
These were taken with a plump bob to a fixed rule, so should be close.
Be interested to see others measurement as I guess setting the caster at the front will make a little difference to the distance.
Mon Mar 26, 2018 11:23 am
Mine were taken from passenger side. I held a rule flat against the end of the sill and then with a helper measured with a tape measure.
Front wheel centre to sill = 335mm
Front wheel to rear wheel centres = 2130mm
Rear wheel to sill = 320mm
I think my car has Metro front hubs, I don't if that makes any difference to that measurement.
Mon Mar 26, 2018 11:11 pm
