It is currently Sun Jun 21, 2026 11:58 am
Speedo
Post Speedo
I can't get the speedo on my coupe to work. I have an MG Metro 1275 engine and possibly Triumph Smiths speedo?
It's the usual speedo found in coupes of this age- mid 1980's.
If I spin the cable by hand at the gearbox end of things the needle moves so I know the speedo and cable are working. Is it just a question of trial and error removing and refitting, hoping the cable will seat properly in the drive, or is the drive incompatible with the cable?
As usual I can't actually see what I'm doing as access to it is tight.
Any advice welcome as always.
Ed
Wed Sep 29, 2010 3:43 pm
Post Re: Speedo
Disconnect the cable at the speedo end and see if it rotates if you push the car along. This will tell you if the drive gears in the gearbox are working.
Wed Sep 29, 2010 8:01 pm
Post Re: Speedo
I'm certain that the cable is not turning whilst on the move. Are there different types of gear and cable or are they a universal size/fit..? I am wondering this because the cable originally connected to an older A series engine and has not worked since swapping over to a later A+ lump.
Ed
Wed Sep 29, 2010 9:08 pm
Post Re: Speedo
Older A series only had one set of speedo drive gears with the speedos altered to suit, later there were different combinations of gears to suit the speedos :? Don't know when the change point was but i'm pretty sure A+ are all the later type.
Wed Sep 29, 2010 10:05 pm
Post Re: Speedo
Thanks Tim, so it could be that the cable is for an older drive and not compatible with the one in the A+...?
Thu Sep 30, 2010 8:30 am
Post Re: Speedo
The square ends on the cable are fairly standard. Maybe it's just not locating correctly or maybe the cable or drive peg have rounded off?
Thu Sep 30, 2010 10:29 am
Post Re: Speedo
Mmm... my cable doesn't appear to be square, more sort of elyptical... Presumably worn.
What cable do I need to buy if I decide to try a replacement...?
Thu Sep 30, 2010 11:25 am
Post Re: Speedo
The drive gear in the gearbox of the Minis all used the same connection to the cable. I suspect what Tim is talking about is the ratios which you will need to consider to get it reading right but wouldn't stop it from reading at all.
The eliptical end of the cable should work OK as it should catch corner to corner in the square of the drive. What I suspect has happened is that the square in the drive gear of the gearbox has split and it's opened up enough to stop it from gripping the cable.
Next to where the cable goes into the box and in the same plane is a small bolt (1/4UNF from memory so a 3/8AF socket). Pull it out and the housing that the cable screws onto will pull off. It usually brings the drive cog with it but watch is it doesn't as there is an oil seal and a spacer that can drop out and end up rolling around in the grit on the floor and you then wonder which way they came out. Once the drive cog is out look at the square in the end for splits and you can even screw the cable back onto the housing and check that the two do engage.
If that is the problem then squeezing it closed will make it work again for a while but a new one is needed and before you order do your sums to make sure the speedo will read corrrectly after by buying the right one.
Iain
Thu Sep 30, 2010 1:54 pm
Post Re: Speedo
Ian, that's magic- thankyou. I will investigate further.
Ed
Thu Sep 30, 2010 3:28 pm
Post Re: Speedo
I have Coupe cables in stock if you need one.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Sun Oct 03, 2010 12:55 pm
Post Re: Speedo
Whats the price of a cable?
Cheers, Alex
(Gulf) GTM Coupe
Sun Oct 03, 2010 6:05 pm
Post Re: Speedo
Hi Alex
The cables are old stock(ex Primo) at
old price of £24 + vat + postage = £30.95.
Cheque to "SPECIALIST ENGINEERING"
as below. Don't forget to include your
address.
Alan
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Mon Oct 04, 2010 6:17 pm
