Boghog
 New Member
Hi, been a member of GTM Owners club for close on 30 years. Built a Coupe in the early 80's bought from Peter Beck and Paddy Fitch from GTM Engineering in Sutton Bonington. The instruction manual and detailed drawings were lacking much detail at the time as it was the early days of their production run. It had a 1300 A series engine rebored, fitted with a road rally cam, twin carbs and lightened flywheel. I ran it for several years as day to day transport, then took it off the road for a re-paint due to severe gel coat fade. It's been in dry storage ever since.
_________________ Early 80's GTM Coupe
| Fri Jun 24, 2011 8:23 pm |
Weasel
 Re: New Member
Welcome to the forum When's it going back on the road then? Looks great in the photo.
| Fri Jun 24, 2011 11:18 pm |
Pantera2075
 Re: New Member
I've been a member of the Mini Marcos OC for 21 years (Jeez that makes me feel old), but I have no intention of ever owning no 4.
Anyway, Hi!
It won't be far off mine then (no.86)
Mine looked good in 1991 too, but now it has degraded to reddish brown/pink.
Mine went from 17 years storage to drag racing at Avon in one easy step.
Get ready for pressure to recommission and engine swap.....
| Fri Jun 24, 2011 11:59 pm |
Boghog
 Re: New Member
I'll have to check the chassis number I think it was 92. As for getting it back on the road, my son's keep at me to do it, I'm too busy restoring a couple of Land Rovers at present. I need a coupe windscreen for starters and I suspect the engine will need to be fully rebuilt or replaced. I always wanted to do a metro turbo conversion or something more modern. i don't know what engines people use now the 'A' Series is getting a bit long in the tooth.
| Mon Jun 27, 2011 9:13 pm |
Malcolm_Ball
 Re: New Member
Boghog wrote: i don't know what engines people use now.... You'll get sugestions and loads of them  Some will be sensible, some difficult and even some that are near impossible Oh yes (again) welcome
| Mon Jun 27, 2011 10:31 pm |
turbocox
 Re: New Member
| Mon Jun 27, 2011 11:02 pm |
Pantera2075
 Re: New Member
I've looked at rotary Mazda engines in the past. Allegedly, it can be done. You need a gearbox with a big dimension between the input shaft and the driveshaft outputs so that the driveshafts clear the engine block. There's an old Toyota box that is a possibility.
| Tue Jun 28, 2011 8:28 am |
Mr Mac
 Re: New Member
Alfa 33 boxer or 145/146?????
| Tue Jun 28, 2011 7:16 pm |
Pantera2075
 Re: New Member
Mr Mac wrote: Alfa 33 boxer or 145/146?????  Looked at that too - would hang out of the front of the subby by about 6"
| Tue Jun 28, 2011 8:12 pm |
 Re: New Member
Pantera2075 wrote: I've looked at rotary Mazda engines in the past. Allegedly, it can be done. You need a gearbox with a big dimension between the input shaft and the driveshaft outputs so that the driveshafts clear the engine block. There's an old Toyota box that is a possibility. Seen a rotary on a civic gearbox, later breadvan style, ep3 K20 engine. Whats been/being done off the top of my head. Honda D16 Honda B16 Honda B18 Toyota 4age Toyota 3s-gte Vauxhall redtop Vauxhall 1600 twin cam A series A series turbo A series KAD 16V Welcome by the way Neil
| Tue Jun 28, 2011 10:08 pm |
Pantera2075
 Re: New Member
Plus, PoP, Nissan CG13DE on a 1.0 gearbox, then later the Almera 1.5 allegedly bolts straight on.
Avoid the 4a-ge - groinal stress.
| Wed Jun 29, 2011 12:32 am |
turbocox
 Re: New Member
WEST wrote: Whats been/being done off the top of my head. Honda D16 Honda B16 Honda B18 Toyota 4age Toyota 3s-gte Vauxhall redtop Vauxhall 1600 twin cam A series A series turbo A series KAD 16V K series T series turbo Alfa...? cant remember what one thow
| Wed Jun 29, 2011 9:48 pm |
Boghog
 Re: New Member
Cheers guys, I'll need to have a look at some of the engines suggested. When I built mine there was someone racing one with and Alfa Sud engine I seem to remember. It did quite well on hill climbs I believe. A light weight aluminium 16 valve, fuel injected engine with a modern gearbox sounds like a good combination as the 'A' series although well tuneable is never going to match a modern engine. I heard the coupe was sold and was to be built by someone else is this true? I always fancied the Cox, somewhere I have an old car magazine somewhere with an article on one that did 0-60 in 6.7 seconds and 100 in just over 13 seconds in 1967, if I remember correctly, which was pretty impressive for the time. In the mid 80's I drove up to Newark Kit Car Show playing with a Porsche 944 on the dual carriageway I had 110 on the clock between roundabouts, and was partially deaf by the time I got there! Of course this was in the days of no fixed speed cameras and there was a lot less traffic on the road. The car was brilliant in the dry but lethal in the wet and overzealous use of the left foot could end (and did more than once) with you facing the wrong way very rapidly! Somewhere I have loads of photos of the build, I'll see if I can dig them out...
| Wed Jun 29, 2011 10:32 pm |
Mr Mac
 Re: New Member
I've been think about an engine swap as well - I did open discussions with MED on a sprint spec A series for next year but since we were heading north of £5.5k our conversations were concluded with a "if you need to ask you cant afford it" sort of comment..........shame as I like the a series. It's left me in a bit of dilemma now.
I'd like to keep the car in line with it's build date so really want to go with a 1980's engine..........which is limiting!
| Thu Jun 30, 2011 11:14 pm |
Mr Mac
 Re: New Member
Or...............
Triumph Daytona 1200
| Thu Jun 30, 2011 11:49 pm |
