r 1 coupe http://www.gtmdrivers.com/forum/r-1-coupe-t2419-15.html |
Page 2 of 13 |
Author: | flippspeed [ Mon Oct 01, 2012 8:02 pm ] |
Post subject: | Re: r 1 coupe |
yes it is nice to see it coming together just need me subframes top coated some time this week hopefully tomz then i can start to build |
Author: | flippspeed [ Tue Oct 02, 2012 7:42 pm ] |
subframes top coated ready to come home hopefully tub ready for the weekend |
Author: | flippspeed [ Tue Oct 02, 2012 7:58 pm ] | ||
Post subject: | Re: r 1 coupe | ||
top coated
Author: | flippspeed [ Thu Oct 11, 2012 7:54 pm ] | |||
Post subject: | Re: r 1 coupe | |||
Author: | flippspeed [ Sun Oct 14, 2012 9:07 pm ] | |||
front support brackets shot blasted and primed , front scoop needs laying up and blending in , subframes should be nearly complete by the end of next week
Author: | flippspeed [ Tue Oct 16, 2012 9:00 pm ] | ||
scoop in progress
Author: | flippspeed [ Sat Oct 20, 2012 1:02 pm ] | ||
delivery from minispares today,bottom arms will be upgraded with high spec rose joints
Author: | flippspeed [ Sat Oct 20, 2012 1:05 pm ] | ||
tie bars are going to work to be upgrade with rose joints and make up some brackets,top arms all rebuilt ready for fitting today
Author: | turbocox [ Mon Oct 22, 2012 10:29 am ] |
Aaaah..............I think I got it now Did you find the owner of the moulds I thought it wasn't going to surface for a while Is it back , is it dermow's Cox In the back ground under the clear sheeting Why are the pictures of a Gtm coupe front end and not the Cox wide body you wanted Is the Cox owned by you now Or have you met up with the current Cox owner to use his moulds For those who don't know this car.... dermot-s-hillclimb-r1-coupe-t206.html?hilit=dermow |
Author: | flippspeed [ Mon Oct 22, 2012 8:12 pm ] |
hi turbocox the car under the sheeting is a fury not the wide body coupe,i wish it was as i would like a set of the moulds,iam going to extend my arches once i bring the tub home hopefully this weekend |
Author: | flippspeed [ Sat Oct 27, 2012 3:30 pm ] | |||||
Post subject: | Re: r 1 coupe | |||||
fvew things to add this week tub has had the sprayed on carpet fitted with some side plates
Author: | flippspeed [ Sat Oct 27, 2012 3:34 pm ] | |||
started on the subframes, been making few bits this week at work will post the pictures tomz
Author: | flippspeed [ Sun Oct 28, 2012 9:09 pm ] | |||||
few more bits put on the subframes and few new bits,tie bars rose jointed got to repaint them as mark up in the lathe ,getting there slowy but ran out off bolts
Author: | flippspeed [ Sat Nov 03, 2012 6:27 pm ] |
The tub came home today the building will start tomorrow |
Author: | flippspeed [ Sun Nov 04, 2012 7:12 pm ] | ||
nothing done this weekend but got myself a new clutch upgrade
Page 2 of 13 | All times are UTC [ DST ] |
