It is currently Mon Nov 09, 2026 5:51 pm
Coupe Questions
Post Coupe Questions
Just picked up a coupe over the weekend.
Couple of questions to anyone that can help!!!!!!!!
Firstly where can i get a build book from - as it didn't come with one
Front radiators - what modern day radiators can be used in replace of allegro and princess rads.
Throttle linkage - where is it available from - Can i use the same one as used on the ROSSA
Also, is the address correct for membership still the same ????
Many thanks
Mon May 12, 2008 1:20 pm
Post Re: Coupe Questions
Welcome to the fold :D :D :D
Build Manual Here: http://www.schwenti.com/index2.php
I'd say radiator is a case of what fits. I don't see a problem with the allegro unit though?
Throttle linkage - There seems to be lots of different designs out there, but I think you could use a rossa's
There's a page on how to join from the front page of the forum - in the stickies. Address was current a couple of months ago when I joined up!
Mon May 12, 2008 1:40 pm
Welcome
Address for membership is current
On the subject of front rads, the allegro one will be fine, if its the 1750 one even better, My old rad was the 1500 one, and would only begin to struggle on long runs on track days where the engine hardly fell below 6000 rpm [my old 1600 Honda engine liked to rev], i do have details of a replacement one which is alloy and will find it out as i managed to get a good deal on mine so can try the same route to others on a bulk buy prehaps. the key thing is to make sure the water actually flows as it should and does not take a short cut through a header tank or heater circuit.
Mon May 12, 2008 3:40 pm
I'm using a Metro rad and it fits just fine.
Mon May 12, 2008 3:41 pm
John, mk1 or 2 :?: I've heard the mk1 has plenty of spare capacity, not sure about the other one though :?
Mon May 12, 2008 6:19 pm
I'm using the one with the inlet and outlet at opposite ends which I think is the Mk 2.
Tue May 13, 2008 7:15 am
Thanks all
Tue May 13, 2008 7:48 am
