It is currently Fri Nov 13, 2026 5:16 pm
Coupe door hinges
Post Coupe door hinges
Is anybody in need of door hinges (beside me) Steve Shield kindly supplied me with the original suppliers name and Gold & Wassall have replied the following
Hi John,
Yes we still have records of this mild steel hinge.
They were 7.1/2” long x 1” & 3.1/2” to c/pin x 3mm material x 8mm dia. pins x 1” joints (8 joints)
Flat backed, undrilled, ‘very tight’. Last supplied November 1993
How many to you need?
Best regards,
Tim Fellows
Sales Director
Gold & Wassall (Hinges) Limited
Fri Apr 04, 2014 10:24 am
Post Re: Coupe door hinges
John,
Do you know if these are the base hinge for modification or as the drawing? -- if the later I should probably have a few for "stock" -- any idea of the price?
Fri Apr 04, 2014 3:37 pm
Hi Steve,
Without your drawing to compare I cant tell if they are the finished product or were modified further by GTM, as they were a special order I'm guessing they were the finished article, If they were a special then we can expect a minimum order quantity slightly above my needs for 2 hinges, I was hoping a few more coupe owners could be interested and if you had some in stock I would buy from you :wink: I'm pretty sure the chap who bought the red coupe off ebay recently was in need. It would be nice if there was sufficient interest to make it worthwhile.
Fri Apr 04, 2014 6:48 pm
Hi Steve,
Yes indeed, that chap is in need of hinges!
Regards, Andy
Fri Apr 04, 2014 10:00 pm
