It is currently Wed Nov 25, 2026 7:12 am
Coupe - Gear Box
Post Coupe - Gear Box
Hi,
I have a remote cast gear change on my Coupe and I’m struggling to make clean gear selections, especially first gear.
Would I be better changing my gear box for a twin shaft change type? Has anyone had any experience changing these over and if so, were the gear selections significantly better?
I have a nice newly made bit of gear change kit from Alan Britton ready for the twin shaft change if need be!
Thanks for any advice anyone can offer ! :)
Tue Oct 25, 2022 4:45 pm
Post Re: Coupe - Gear Box
Hi Ken
I used the old cut in half remote change on my old Cox long and found the changes OK apart from slipping into the reverse slot on hurried gear changes, I fitted a hinged lockout to cure this.
Mini Spares do a spring load kit that pushes the gear leaver into the 1st-2nd slot, but as I've not tried it can't comment if its better.
I'm sure Alan's rod change Kit will be better if you change the box, I use a twin shaft change but pass the selector shaft through the front of the box not underneath.
Wed Oct 26, 2022 7:44 am
Hi John,
That’s very helpful, thanks for that. I’ll check it all out.
Fingers crossed!
Thanks again
Ken
Wed Oct 26, 2022 12:13 pm
