Re: coupe rear wheels and bearings ..
yes there is ment to be a spacer inbetween the bearings, and comes as a matched set with the wheel bearings when new as they do vary slightly to take out dimensional tolerances,, I always keep my old ones as i have one upright which must be at bottom limit as when i fitted a new wheel bearing it was very slightly loose after tightening, so i measure and set them how i want them these days.
the space is seperate on taper and some roller bearings, some roller bearings have the shim built in! i did come across these once upon a time
the dimension of the spacer from memory is somwhere around 0.350"
[inches]
WEST
