It is currently Fri Nov 13, 2026 5:06 pm
Final Drive Ratio Recommendations
Post Final Drive Ratio Recommendations
We've kicked off our Coupe project this week starting at the bottom by rebuilding a 1275gt gearbox.
It was fitted with a 3.44 diff and I have a 3.7 available.
As it's a 13" wheel model, what ratio would you guys recommend?
Also, what tyre size do you run on the 13" wheels?
Andy
Thu Jul 28, 2016 8:54 am
Post Re: Final Drive Ratio Recommendations
It's a question of what your using it for?
And your personal driving style.
Myself I would go for the 3.76.
Thu Jul 28, 2016 9:35 am
I was wondering this for a race car using Cooper s C/R gearbox, I was thinking more like 3:44 but mine is going to be 10" wheels, so probably work out the same!
Thu Jul 28, 2016 9:39 am
That's how I worked it out :wink:
But I have run the 3.9 in the Cox :shock:
That was Scary!
Your not what you call driving, your more holding on, using the force. JUST.
I've run the 3.76, too, but obviously I'm not running the high revs of normally aspirated, due to the turbo.
Thu Jul 28, 2016 9:58 am
Back in the day I ran 2.95 on a mg metro engine suited my intention, it ment 60 in second was achievable
Thu Jul 28, 2016 10:41 am
On my old Cox with 1430 engine I used 3.44 with 10" wheels on the road and also used to sprint it using 13" wheel fitted with P7 (50% I think) these were the lowest profile available back then.
My twinny mini was built here in Kano using 3.9 diffs in both engines and one of them is in the back of my GTm on 13" wheels i doubt I will use less than 60% aspect ratio tyres when its time to buy :wink:
Thu Jul 28, 2016 10:50 am
