grizzler73
 Odd Scoop
Evening all Dragged what is left of my GTM back to the ranch last weekend. Pile of rust that was a chassis is gone to the local scrappy, I even got a whole £6 for it! The body will live under a tarp till the workshop is finished but I thought I would ask what people make of this scoop on the passengers side rear, is it original? My feeling is not.  [/URL]
| Wed Nov 02, 2016 10:10 pm |
turbocox
 Re: Odd Scoop
I've seen them on quite a few drivers sides, and I've seen one, on the passengers side, but only one. But........
| Wed Nov 02, 2016 10:51 pm |
 Re: Odd Scoop
I have seen a couple but smaller compared to that example, look at Dinos rebuild thread you can make it out on some of the pics on the drivers side similar shape but smaller.
| Wed Nov 02, 2016 11:06 pm |
kano nordie
 Re: Odd Scoop
On my old Cox I had air intakes on both sides the R-H was a cold air feed to the oil cooler exiting out the top of the engine cover and the L-H side was feeding the carb air box. John
| Thu Nov 03, 2016 9:50 am |
grizzler73
 Re: Odd Scoop
I have seen a few on cars but can see none from period shots so I think it is something added on later, my car had the rad in the rear so I suspect it was added for that. judging by the amount of chicken wire, filler and fag packets holding it on I don't think it was a factory option! Another hole to fill....
| Thu Nov 03, 2016 2:10 pm |
turbocox
 Re: Odd Scoop
Personally I'm all for originality, (my current Cox spec excluded  ) My opinion, I think it looks s##t, sorry but I've never liked it. As you rightly said it looks like it's been stuck on, And if you have a half decent rad and bleed the system properly it won't get hot, mine doesn't.
| Thu Nov 03, 2016 3:17 pm |
grizzler73
 Re: Odd Scoop
Exactly Stuart, it looks worst in the flesh! I will have a front rad anyway and keep the one on the other side which will feed air to the oil cooler. I am thinking of building an air box to get air from the engine cover grill for the carbs, I saw a nice setup on a racing imp at Brands earlier this year I might copy.
| Thu Nov 03, 2016 3:29 pm |
Steve Shield
 Re: Odd Scoop
I was just about to open a thread on this -- mine's got a 'home made' effort on the LHS. I'm planning to get rid.
| Fri Nov 04, 2016 11:02 am |
grizzler73
 Re: Odd Scoop
Yes that is not nice.... I notice you have a Unmolested Cox style bonnet, ever thought of making a mould? Hint, hint...
| Fri Nov 04, 2016 12:52 pm |
grizzler73
 Re: Odd Scoop
Steve you have a PM Simon
| Fri Nov 04, 2016 3:14 pm |
kano nordie
 Re: Odd Scoop
Nick, If you put a cold air feed to an airbox from engine cover I think you will find the engine cover is a low pressure area and will draw air out rather than what you need, air to be forced in, I had an oil cooler with an outlet under the engine cover and it worked well. John
| Fri Nov 04, 2016 4:29 pm |
