It is currently Fri Jun 05, 2026 10:41 am
Spark Plug decoder, NGK
Post Spark Plug decoder, NGK
Found this handy little spark plug decoder ring :lol:
usefull if your into swapping plugs around to suit a certain application
http://www.spark-plugs.co.uk/pages/technical/ngkjpg.htm
Sun Sep 07, 2008 11:07 am
Post Re: Spark Plug decoder, NGK
Thanks for that. I had it once then lost it when I had to reformat my computer.
Sun Sep 07, 2008 12:41 pm
Just had a quick look under mini for the coupe guys, it lists one heat grade of plug I looked at ngk, they will sell me any type as long as its a "6" heat level, and for that matter all austin cars mini spares recommend a BP5ES as standard for 998/1275 and a 6 for hotter.
or am I missing something?
The owner isn't
Tue Jul 21, 2015 8:17 pm
Here is the NGK Catalogue site this has got the info on the makes and models of cars that our GTMs have stolen the engines out of
http://www.ngkpartfinder.co.uk/
Gives details about the car models covered and the plugs they recommend and the plug gap
Then if you want to change the make use a cross over converter as you now have the ngk part number, most companies can't be more helpfull when you want to do this
here is the Champion site gives you more details about the spec of the plugs to
http://www.championsparkplugs.com/find- ... a_JNvlViko
The owner isn't
Wed Jul 22, 2015 5:50 pm
