It is currently Sat Aug 22, 2026 2:35 pm
Fitting dizzy.
Post Fitting dizzy.
Hi, my new electronic dizzy has arrived so am on with fitting it. It has not had one fitted since it was built. I have set to tdc on number one with number 4 rockers level and loose. Should the rotor arm point to number one plug with the metal part or the plastic part. It is only a minute job to turn the dizzy drive if it is 180 out.https://www.dropbox.com/s/ly9goxhnbnj7j ... 5.JPG?dl=0
Sun May 14, 2017 10:09 am
Post Re: Fitting dizzy.
Try this courtesy of mini mania....
or read the haynes manual
http://www.minifinity.com/forum/viewtop ... =5&t=80695
The owner isn't
Sun May 14, 2017 11:04 pm
Basically, with number one cylinder at TDC AND with both valves closed on cylinder 1 the metal contact on the rotor arm should be pointing towards the distributor contact point for number one cylinder plug lead.
This should allow you to start the car after which you can use a strobe to set the timing accurately.
Tue May 16, 2017 12:24 pm
Did you mean level and "tight" (valves open)? Level and "loose" is TDC compression - not exhaust so #4 would be firing.
Wed Jun 14, 2017 12:52 am
