Re: What coolant temperature are you seeing with an 82 deg PRT?
garyo wrote:
Can anyone confirm - where is the sender for the gauge, for either engine type? Does the ECU tend to have its own sender?
Both senders are in the same casting where the coolant flow exits the head. Blue connector is for the gauge, black (sometimes brown) is for the ECU. This on the 4cyl VVC, not sure where they are on the V6
